Re: 14mm ballscrew + nut for VMC260
i would go to at least a 4 or 5mm pitch and change the gearing to retain the ratio. it's possible to use a flanged nut and mount it from one side, as the original is mounted this way. I've replaced a full set of ballscrews on the 260 and had a nightmare to get the nuts sorted. I'm currently helping a friend replace a 240 x axis ballscrew with a standard flanged nut and all looks good so far.
the reason i say go for a larger pitch (5mm), is you get a far stronger ballscrew which will give probably 5 times the life of the 2.5mm pitch screw. These boxford ballscrews are a common fail point, and are just not upto the job.
