I Must say thank you to all who are helping with this thread/problem as i wouldnt have a clue without you all.
Rick.
Rick.
Rick,
My Lenze 534 has blown the same transformer...
Did you replace wit the above recommendation and did it fix it?
Simon
We've not arrived at a decision yet as we are not sure what the correct secondry voltage should be, i was hoping someone would have a look at a working one but it appears nobody has voluteered yet.. LOL, I could be that nobody has one they can look at but i suspect the answer will come up soon.. I HOPE. Im really stuck as i cant use the machine without it...
Rick
Ah... ok thanks... That is where I am at too...
I've asked someone to measure their working one and will report back if I get anything.
Simon
Someone near me has just had the same problem!! I've just measured the voltage on my (working) unit and both secondaries are showing 15V RMS with the drive powered but the motor static.
Suggest checking the rectifiers as well as the suggestions above. it looks like a long term overload causing heating rather than a short term 'bang' scenario.
Good luck!!
David
Ha... my "remote-voltage-sensing-fu" is working well :)
2x15 V: VB 1,0/2/15 from Farnell £2.07p+VAT but min order value £20
Same from RS £3.74+VAT, free p&p but out of stock till Oct.
Same from CPC £ 3.18 inc VAT + P&P and in stock. Note: this one has 2 x 115v primary so may need minor mod to pcb?
I replaced the transformer yesterday... The output now pulses from on to off when commanded to a speed. Something else must have gone on mine too.
Time to replace with new...
Fingers crossed for me then LOL
Rick
New transformer has been fitted but not yet tested, and I also found that C6 (.47J100) {470nF 100V Polyester Capacitor} has also failed, so that will need to be replaced.
I also don't trust the looks of C5 (4.7uf 63v Electric Capacitor) so I am also going to replace that.
