is that good???? ive looked at the manual, but how easy is it to connect to a BOB board (if it can be run off a BOB board)
Hi Nik
The 6400 is a programmable motion controller we have some of the old 6200 which I have programmed, not really any good for CNC.
You will have no problem running the drives from a breakout board.
I have some of the same drives which I removed from decommissioned equipment at work, I haven't had time to play around with them yet.
Is there anything in particular you want to know about the drives?
Andy
well as they had their own mains connection i did think i wouldnt need a big transformer or power supply to run my motors, thus an easier way to supply each motor, being a newbie i was hoping it was a simple act of connecting to the right break out board and they would all work in harmony, but as i didnt give anything for them its no loss,
what actually comes out of a break out board to in turn make the motor driver do what it does
Just a 5 volt signal,the direction signal is either high or low which determines which way the motor turns and the step signal is a pulse (square wave).
If I get time this weekend I will connect one of the drives I have to a motor and have play then let you know how I get on.
Andy
thanks andy thats great, but.........well it gets worse.......... popped in to see a mate today, id mentioed i was going to build a cnc plasma and should he come across anything keep it for me, well.............
Attachment 9518
Attachment 9519
Attachment 9520
Attachment 9521
ive got 5 decent sized machines, was in excess of £125,000 each, all with 2 heads that machine 2 items at the same time, so ive got 10 lots of z axis setups,everything to run them as a stand alone system, even temperature controllers to keep them warm/cool, i'll list everything one ive managed to strip just the one, but take a look at the pics and see you guys think
WOW, I wish I had a friend like that. Well done!!! G.
Hi Nick
Looks like you might have some useful stuff there.
The Trio Motion controllers are pigs to program (in my opinion anyway)we had a machine at work that used them we ripped them out and replaced with the Parker stuff.
Keep us posted.
Andy
What a jammy barstuard
