Well YES.!! . .. Compared to sanding it away with emery paper then I'd certainly recommend it Robin. . . .End of the day it's all relative to the job in hand and the tools available to you.? . . . Certainly better than nothing.
To be honest the same could be said for common milling machine conversions when it comes to cutting or engraving aluminium or 3D work in aluminium.? Compared to a stiff router like Jonathan's new creation then your typical slow running spindle milling machine will be inferior just like routers are for cutting steel.! . . Same principle really.!!
Yes typical Milling machine conversion will cut and engrave Ali and do 3D work in Ali but in comparison it will be much slower due to it's snail pace spindle.!!
Don't knock what you haven't tried.!!
