Re: Advice on spindle inverter spec
badgerman
			Good thinking. I might get back in touch with the KEB rep and see if he can reverse engineer the menus settings. I know you can connect it to a pc so I might try that too.
 Careful here you can easily wipe the settings back to default or if doing a firmware update screw things up. Before messing Make sure you Wright down all the relevant settings.!!
 Already done, I created a document to explain the differences and communicate the values in my inverter to the KEN rep.
		Just get an inverter based on motor current and voltage and the input voltage you require e.g. 240v single phase. I have found these people very good
AC Inverter Drives (230V) (Page 1 of 43)
The motors shown are slightly odd in that they are 200v and 185v when connected in 'star' as shown on the rating plate, normally a motor would be 230v when connected in 'delta' and 415v in 'star'.
Obviously these are bespoke motors.
