Re: Nooby Flying Gantry Rig
Still yet to fully design the Y and Z axis, planning to use 16mm rails for both and a basic leadscrew system...
Trying to keep costs to a minimum whilst using premium parts so that they can be reused at a later date when I update the system.
Anyone experience with running 2 steppers on a single axis? I'm assuming I can run a 4 axis controller and use mach3's stepper synch functions.
Well I have 4 steppers, so might as well set the system up to use them..
As for the router suggestion, I would do that, however my router collet doesn't grip the bit at the moment so I can achieve a good cut as after a short distance the bit will slide out.
My hand isn't stable enough to cut straight with a jigsaw, and there is no immediate rush.
I have seen that before, and the theory of 2 steppers on a single axis seems fairly simple since the steppers will give mach3 feedback and error correction.
All I need to confirm is that a 4 axis stepper controller will be able to run 2 steppers on the X axis.
I also need to sort out power supplies... How much wattage am I going to need.... Dont you love electronics :P
I'll be alright, play it safe and get something with more than enough power...
Depends on what controller I go for...
I was thinking about using the routoutcnc boards or even taking a jump in the deep end and use a 4axis board from china...
Although I cant find much feedback on those for obvious reasons.
Had some free time away from baby this morning so I cracked on!
Decided to get a shift on with the gantry, no real work in progress shots, but you can see where I am up to...
http://i414.photobucket.com/albums/p...n257/002-3.jpg
http://i414.photobucket.com/albums/p...n257/004-3.jpg
Next i'd like to sort out some nuts that I can fix to the gantry then I can mount the X axis screws and steppers.
Hi Conan,
If you are still thinking of swapping the Pine for something more stable why not try
http://www.aluminium-profile.co.uk/a...10mm_Slot.html
Its cheap, cut to length for you, Very accurate and very very easy to mount on also strong as hell due to the profile!
Michael.
Reckon since I've got a load of wood sat here, i'll push on with it for the time being...
With any luck machine #2 will be an aluminium machine :)
It can get addictive, What are you using for lead screw /nuts?
Michael
I've got 2 dead straight M8 studding bars for the X axis, I was going to use self made delrin nuts but i dont have any way of drilling perpendicular to the material.
So i'm on the search for some nuts that I can screw to the gantry.
I plan to use M8 for the Y axis and either M8 or M6 for the Z.
