Try these blokes they are excellent for things like this. I can't see any on sight but I bet they will have or will get you some.
http://airaccessories.fluidfittingsshop.com/
Thanks for the info on the grease nipples guys.
Does anyone know what is the best type of grease to use in these linear rails ?
Dave, some lithium 2 should get you off to a good start it's also what I use, cheap as well 400g tube - £3 should last you awhile.
.Me
This is the one I use, it's the right stuff at the right price.
http://www.toolstation.com/shop/Auto...0/sd180/p89691
Also read this thread
http://www.mycncuk.com/threads/4862-...3206#post33206
First thing is, I would not recommend using the Hiwin size 15 linear bearing blocks because they are an abomination to grease. If though you do have them like I do, I found a good thread here about greasing them.
http://www.camheads.org/showthread.php?t=4431
