Sorry the z axis wiring and board won't drive any of the other motors.but I did check the z motor and it works fine using the x axis wiring
Sent from my SM-G361F using Tapatalk
If the Z Motor worked on X axis then the X motor should have worked on the Z axis so either driver, wiring or Config is the problem.
Here are motor output, input signals and output and port setuphttp://uploads.tapatalk-cdn.com/2016...39c080532a.jpg signalshttp://uploads.tapatalk-cdn.com/2016...076a2246c1.jpghttp://uploads.tapatalk-cdn.com/2016...31a0fa2b7e.jpg
I just for it to work the wire from the out puts were in the completely wrong place.just need to fix the driver output for the plasma now
So Z axis now working ok?
Yes he had it fitted to pin 1 and 2 it was ment to be in 6 and 7
