m_c
			Just to clarify, are you running code from the memory stick, or copying it to the PC before running?
I have heard of a few times where running from memory stick/external drives that has caused problems.
There are settings where USB will go into a low energy/power saving mode after a set time of inactivity, and if it does, it takes a little bit longer for Mach to read the next chunk of code, which can cause it to stall briefly. Copying the file to PC should eliminate that issue though.
