Hey Bladevane;
Could I also get a link to this older version of emachineshop?
Much appreciated.
[email protected]
Hey Bladevane;
Much appreciated.
[email protected]
Hi Bladevane, please send me the old emachineshop thread My email: [email protected]
I have added you to my Dropbox folder so you should have access to eMachineShop versions 1.932 and 1.935. Regards.
Is there a possibility to modify or hack the latest version 1945 to export DXF and have all the functions working?
I have no idea. My understanding is that after version 1.935 you must pay to export DXF.
Hi Bladevane. Please add me to the Dropbox. My email is [email protected]
Thanks a lot.
Jack_, all sorted. You should be added. Regards.
I was searching for information on eMachineShop and saw this this forum and post, so hope you don't mind me asking if you could possibly let me download version 1.932 as hopefully it will do what I require. My email is: [xxxxxxxxxx[/email]
Thanks in advance.
Chrisinessex - all sorted. You should be good to go. Regards.
Thank you, much appreciated.
please someone can send me version 1.935 ot [email protected]
thx!
You now have access to Dropbox and should be able to download versions 1.932 and 1.935. Regards.
Hey Bladevane,
Would you mind adding me to the drop box with the older versions and sending me the link?
[email protected]
Thanks!!!
thanx for shared the folders but I need the ems.dat archive of appdata/roaming or setup archive. Best Regards!!
yhanx
do you have the installer file ?. It asks me for the file "... / appdata / roaming / emachineshop / ems.dat" or does someone share that file for version 1.932 or 1.935 please
@Shoeless - all sorted. You now have access to Dropbox and should be able to download versions 1.932 and 1.935. Regards.
@begno - I suggest you Google "appdata / roaming / emachineshop / ems.dat" because it has never been a problem before with other users. Maybe it is specific to your PC. Regards.
Bladevane I would appreciate a link to the dropbox for the earlier versions
my email is lotusdriver@gmail dot com
Sorted.
Hello there! I really appreciate what you're doing, could you add me as well?
[email protected]
Jordan, All sorted. Regards.
Many thanks bladevane
Now if only there was a fix for keeping stl export :-)
Bonjour je suis nouveau sur le forum j'ai le même problème que tout le monde je viens de réinstaller la version à 1.35 voici le lien http://ul.to/ied8ngur
Translated - Lee
Hello I am new to the forum I have the same problem as everyone else, I have just reinstalled version 1.35, here is the link http://ul.to/ied8ngur
Bonjour en installant la version à 1.935 et en mettant comptabilité Windows 8 on peut récupérer les fichiers dxf mais on a pu la fonction vue 3D si quelqu'un la solution ou une idée merci
Hey, I'm not a machinist, and only a 3d printer user, but I just wanted to THANK YOU for this incredibly helpful information. I have been using EMS for years to design 3d parts and the .stl files for my Prusa slicer. After the recent update (no idea why I did that, for something like this, if it works, I usually leave it be...) removed .stl export until a $200 bounty was paid, I tried several design apps and none came close to the ease of use and simplicity EMS provides. So getting that back is tremendous. Were you in sunny florida, I'd buy you a beer.
Thanks very much. - Mike
And thanks to Bladevane for getting this thread going.
(BTW, I actually paid EmachineShop way too much money to fab a part for a FXR, a few years ago, so I don't feel too bad using their app for my own purposes!)
Salut à tous. Toujours un peu embêté avec le logiciel mais ça va. Voici mon adresse pour avoir la version à 1.32 Si quelqu'un veut bien me la donner voici mon adresse mail
[email protected] à toute l équipe
Benoit, Je vous ai ajouté à Dropbox afin que vous puissiez télécharger les versions 1.932 et 1.935. Après le téléchargement, vous devrez appuyer sur Ctrl + E lorsque vous déroulez la liste des options d'exportation, puis redémarrez eMachineShop. Regards, Glyn.
Sure. I’m away for a few days so will do this early next week. Regards.
You should have access to versions 1.932 and 1.935. Good luck.
Dear Sir,
Would you please include me in the list? [email protected]
Kind regards
All sorted. You should be able to access versions 1.932 and 1.935. Regards.
Hi
Would be much obliged if you could add me to your list
Regards
John
johnsattuk at outlook dot com
John, should be all sorted for access to versions 1.932 and 1.935. Regards.
Hi Glyn,
Would you be willing to add me to your list, as well?
prodigalpogue AT gmail DOT com
Thank you kindly,
Patrick
Patrick, All done. You should now have access to versions 1.932 and 1.935.
Regards.
Hi Glyn
Could you please to add me to your list?
tgh071 AT gmail DOT com
Best regards
Toby
