Re: Ready to push the button and buy a laser....
Oh well, one down, one to go....
The rotary attachment arrived today - totally wrecked as the chuck had broken the shaft that mounts it and was loose in the box, unusable and a complete waste - the box that should have held the chuck was in there so why was it fitted??
My thoughts were previous customer return item.
emailed supplier with a photo.
Oh dear, not good.
My rotary attachment is still bubble wrapped but mine is the simpler, cheaper unit with no chuck, just a set of stepper driven 3 rollers to hold a glass or bottle by friction.
Can't see it ever getting used.
I did see another one of the type you have on a forum somewhere, where the spindle had pulled out of the upright because the bearing was a loose fit but it looked an easy fix if you could get redress off the seller.
This would be an easy fix - re-weld the plate and true up on the lathe but that's not the point :)
See what they say in the morning.
3 Attachment(s)
Broken weld, if you call it a weld...
Attachment 21108
Put the chuck box in though, thats a nice touch...
Attachment 21109
Nice wiring....
Attachment 21110
JS probably saw my post here on Madmodder - see reply #23
http://madmodder.net/index.php/topic...html#msg126523
Oh, and my cable outer also was stripped too far back to use the clamps like yours, but I found that by friction warming the outer by gripping with a cloth and sliding it, I could ease the outer far enough down the wires to get under the clamps (which are too large a diameter to grip, but a bit of the serrated end of a tywrap makes up the gap sufficiently !
Supplier reply - can i get it fixed locally and how much?
I guess £50 will cover it :) See what they say.
Mine ended up £40 under asking price. They've just this morning sent me an eBay message asking if it's arrived and am I happy with it! Considering I told them it arrived broken, sent photos, got a discount, and left them neutral feedback you'd think that they were aware of my opinion by now!
As this was a package deal, i think the rotary added about £100 over the price of the basic machine so £50 seems reasonable i think.
They certainly don't keep track of orders very closely it seems in your case ;)
More like it...
Attachment 21117
Ground the bird-sh1t off, turned a bevel on the stub so there was somewhere for the weld to fill, nice heavy fillet, turned the flange true to the shaft, refitted it.
Also drilled a couple of divots for the pulley screws to locate into.
I'll also replace the crap allen screws which appear to be M6 but have a socket that fits nothing with some proper M6 ones !
Davek0974
More like it...
Attachment 21117
Good recovery Dave
It has been said before that this Chinese stuff has to be considered a kit of bits
