Re: To do or not to do, can it be done?  MK4 drill steel.
		Thanks again Neale.  A lot to consume.  I looked at the difference between rectangular and square tubing and agree the benefit is negligible.  I watched "This old Tony" video https://www.youtube.com/watch?v=jOvGv9aRKFs where he cuts steel with his build using closed C Channel on the gantry.  He sand filled the frame and it is a fixed gantry.  I'm sure a huge advantage and not comparing apples to apples for what I need to do.
		Before using This old Tony as a source, watch this. About two minutes 30 in...
https://www.youtube.com/watch?v=Ogwp7zD59og
		I'm not surprised TOT  is going this route.  I think he likes old machines and rebuilding them.  If I had an opportunity and a bit of an inkling I'd do the same but it wouldn't meet my immediate requirements.  I think what he is saying is a router isn't a milling machine nor is it a drill but my choices are limited short of resources $$$$.  I also like the guy who built the granite router.  https://www.youtube.com/watch?v=d3f3vknWj-w Now that is stable and possibilities are interesting.  Again not now.  That probably shouldn't be called a router.
That brings me to the granite guy claims on the Jianken spindle.  He gives it much credit.  Has anyone here used it.  This video shows him doing, by mistake, a 10 mm deep 8 mm wide aluminum cut. https://www.youtube.com/watch?v=h9q6j7POgOI&t=982s
Pretty impressive for what might be called a router.
Oldtech
 Funy, I watched that same video last night.
