If the mill has been converted to Mach 3, then those wiring diagrams will most likely not apply.
Also, Denford never had an option for a touch probe, so there will be no dedicated wiring in the original Harting connector for one. You'll either need to see if there are any redundant wires in the plug from the retrofit, add new pins, or run wiring externally for a touch probe.
I ran an external wire
