Finally finished. We needed to strip down some of the machine to route the wiring, then it was time to upload all the information to GitHub.
https://youtu.be5aAXnm29t5g
I'm a bit bemused by this. In my experience of breaking cutters the spindle has never stalled, if it had the cutter might not have broken! The last one I broke I made a mistake setting Z height and the machine made a rapid move straight down into the work, fortunately not through the spoil plate. The spindle carried on regardless! Am I missing something?
Cutting 1000 grade thin sheet tend to gum up the cutter. It’s almost pure aluminium. Then it stops cutting and the spindle stalls and the end mill breaks. 6061 alum alloy is better but if the bit gets hot again it can gum up. Mist or flood cooling minimises this risk but it gets messy.
Well, I'm still bemused. If it's the cutter that stalls the spindle then it has to take all the momentum of the spindle to stop it so the instantaneous torque on the cutter must be much larger than the motor torque. As I said The motor hasn't stalled any time I've broken a cutter. Anyway it will be good to hear of your experience with the system - will you be doing some controlled experiments?
It's going to be very dependant on your machine. If you have a low powered spindle, it seems it will stall before snapping. Presumably on such a machine, the axis drives are likely to bog down if the spindle stalls, in which case(s) you appear to be able to kill the drives in time to save the cutter. It wouldn't be much use to me, based on my own unfortunate experiences, as it's the axis motion that causes breakages pretty much instantaneously when the cutter stops cutting - usually due to recutting / chip welding in my case. The answer to that is chip evacuation by air and/or coolant.
It would also be redundant if your VFD had a "spindle at speed" output but again, it's only going to be relevant in some applications. Although the Yaskawa spindle VFDs I've used on my machines have that feature, it would be of little use to prevent cutter breakages. Instead, its used to allow the spindle rpm to reach the programmed speed before the next G or M code is executed.
It's only a 1.5kW motor and so once the cutter is clogged with aluminium it turns into a cylinder being pushed through the material as it is not longer cutting. This brings the motor to a halt fairly quickly but the axes keep moving and so the end mill breaks. The inertia of these Chinese WC motors is pretty small as the rotating core is quite small in diameter. Tends to happen in thin materials as they are almost pure aluminium, not a high alloy content, although cutting 6061 dry can have the same effect but usually a lot less often. Mist or flood cooling helps significantly. I'll use the system and see how it performs over time, rather than specific experiments. The few test runs I've carried out (some were in the video) all work OK. My main concern is how the PLA will perform over time with heat build up - it is only a friction fit so it could slide down, same thing with the sensor disc.
