Cheers Guys
I will surface the spoil board again just to be sure but it does seem flat when i test the difference between the end of the bit and the surface using the 10mm block. I do not have a DTI but I have ordere one today so hopefully will be able to check things with better accuracy. Will let you know how it goes.
Al
