It may not be much use but Pacific Bearings have a 'square' bearing using hi tech plastic as the bearing surfaces, each side can be adjusted for clearance .. but I think these may have to run on steel box section ...
No probs with the drawing, probably took me less time than trying to explain in words.Quote:
Thanks for taking the time to do the drawing, the closing plate idea was going to be my strengthening measure if the channel flexed to much. Using box section as a rail but rotated had occured to me, but I was put off by the radious on the corner of steel box section, Ally has a nice square corner but wouldnt last long with the bearing running on it, I'll try running a bearing along the edge of some steel box and see how the V matches the radius.
Well at least you should have have enough options now.......looking forward to seeing some pic's
Not sure I would bother personally, looks like theres alot of surface contact so high friction and being fully enclosed means the rail cant be supported. I would also guess that the rail would have to be solid as box sections often have slightly concave faces.Quote:
Still i'm sure someone will prove me wrong :heehee:
Still pondering at the moment
Just out of interest I've attached the model in DWF format, you'll need Autodesk design review to view it, tiz free
http://usa.autodesk.com/adsk/servlet...&siteID=123112
Still got some fettling to do
