Re: Mounting motor under table?
Right, the "intended use" question.
1: PCB milling (from one extreme...)
2: Panel making for instrumentation - aluminium and as-yet-undetermined plastic, <5mm layers, mostly cutting external borders, internal holes for switches. Engraving text. Nothing intricate.
3: Small components as needed for above, odd little brackets etc. Aluminium mostly.
4: If possible, larger aluminium pieces. The "low gantry, tall Z" design is because there might be the occasional taller but narrower piece. (...to the other)
Ideally making new bits to improve the mill or make a bigger, better, shinier one!
I don't expect it to handle steel but you can flippin' well bet I'll give it a try to see what happens :naughty:
I'm hoping that I'll be able to make it stronger/more sturdy by leaving the gantry to handle Z. It also means I can consider adding a counterweight system later if I get adventurous or drunk. I have no idea if it needs one, I just always thought they looked cool. Not... ehh... a proper "technical" answer, I know :redface:
if you plan to do lots of 3D and intricate V carving
Engraving would be flat text for a control panel, nothing fancy. I might need to do something fancy every now and then to try and justify it to my wife, but thankfully she has low standards. Well, when it comes to husbands, anyway :whistling:
Jonathan
Maybe engraving, but generally for engraving it's relative position that matters more than absolute which means microstepping is more valuable.
Ermm. . . Not a good idea IMO realying on micro stepping. Really it's horse's for course's when you get into the finer engraving area and resolution rules. So it's finer pitched screws all the way but at the sacrifice of speed. . . . If I intended main use as engraving then fine pitch's would be used for the resolution not M-Steps.
Micro stepping is good but mainly for smoothing motors.
Rogue
Scrap the last post then. .:rofl:
This is one of the things which I need to get my head around as well. From what I read, microstepping is good... but it's bad. People report motor problems disappearing when they start to use it, but from what you say it seems to be an inferior way to achieve good resolution. I'm assuming that there is a middle ground somewhere that I need to find (not too fine a pitch, not too many divisions for microstepping).
Rogue
Depends on a few factors really and the drives being used also play a big part to how micro stepping is implimented.
10x micro stepping is about the max usable and beyond this is just pointless unless you have a very high pulse width which is beyond the capabiltys of the std parallel port. . . It's gets complicated so wont go there.!
Generally micro stepping should be used but mainly for motor smoothing at lower speeds IE: small tiny moves and lower rpm's but after a point micro stepping becomes an inderence more than a help and this where the drive comes into play.
A good drive will use a technique called morphing where it changes from micro stepping to full stepping along the power curve. This also brings resonance into play and why belts can help.
Poor drives without morphing and usually mid band resonance compensation can suffer from resonance issue's caused by the vibration frequency's that interfear with signal performance and affect the motors making them run really badly and sound dreadfull. . . . Belts act as a natural damperner.
Good drives like Gecko's etc use morphing and Mid band resonance damping and this really does make differance.
If you work on the principle that micro stepping works but mainly to help with motor smoothing at lower rpm's but with the side affect of slightly improving resolution ( too a point) then you wont go wrong. Just don't relay on it soley to give you the resolution you need.
Like I say the good drives do make a big difference.
Go to the Gecko site and read the FAQ section it has some good info on how morphing and micro steeping works.
I... ahh... won't go into my original driver plans which involved a PIC and some fairly shaky ASM :whistling:
I was actually looking at the linistepper kit originally, again on the grounds that I could probably put a set together for the cost of a single Gecko in the short term. I know "short term" is a dirty word on this board, and knowing my luck unipolar motors will have a whole extra set of problems attached to them :rolleyes:
In my experience with helping folks who have try'd to make your own drives and use oddball steppers etc becomes false economy with the end result being wasted time and money.
Good for the experience but with the same result. . Inferior performance and poor reliabilty . . ending in scrapping and buying "Proper drives an motors".! . . .BUT. . .By no means let me saying this put you off thou because it's all a good learning experience. . . Keeps you out of mischief as well. . Lol
...Inferior performance and poor reliabilty...
Another reason I'm glad my wife has low standards.
I've got some odd steppers lying around to play with for PIC projects, though I had grand dreams of extending functionality in ways that isn't actually needed or, indeed, useful.
Steppers are far enough down the line that I'll hopefully be better placed to source better components. I plan to make up some linistepper drivers anyway, whether or not for the CNC, as there's always mischief to be gotten into!
I'm not saying rely on it, just it might help. Clearly the result will be slightly distorted.
I already mentioned about microstepping accuracy (or rather lack of) in post #15...
One thing I'm going to try and do with my stepper driver design is make it effectively run using microstepping, for smoothness, yet only require the number of pulses for whatever microstep division you choose. Effectively it will move through each of the microsteps for every step pulse.
