Re: parralell port voltage.
crossleymarko
so the 3.3v is converted by the bob.. to 5v is this right.
Ermm what bob is it.? you don't need 5v just a big enough difference between Hi and Low at 3.3v there's not a big enough differential and so unreliable signals.
Give me some details of what you have and I'll have a look.
John S
Port 0, pin 0 ?????????
should that be port 1, pin whatever ?
i watched a setup vid on utube.. he had estop enabled, port 0 pin 0.. is this wrong, what would this settin do.
crossleymarko
Yes it should be port 1 and then the pin you assign it to on your bob.
Like i said before post the XML file and I can load it into Mach here and check it for you. Often it's just a simple setting that like this that stops every thing working.?
http://www.ebay.co.uk/itm/CNC-Router...#ht_7034wt_972
heres the kit. i dont have an estop so i thought the settings pin 0 port 0 still enabled was ok , sorrry,
ill send files now
http://dl.dropbox.com/u/19756368/Mach3Mill.xml?dl=1
http://dl.dropbox.com/u/19756368/Mill.xml?dl=1
these are the 2 mill shortcuts i have.. i use each one... as you can see on my desktop i have mach3mill.. and mill..
its a fresh install of vista..
Do you have manuel for the Bob which gives the pin settings etc.?
Don't use the Mill xml it's all screwed up.
i dont (i think) ill delete it...
ill have a gander
whos manuel... lol are you on ya jollys jazz...hahaha
No but i'm not working tomorrow that why the late one. . . See PM.
Manuel.!! . . The spanish waiter . . Ce Mr fawlty. . Lol
Bed time.!!
that 1 post took 2hrs....arrrgghhh. friggin laptop.. gonna sort it when i get a min.
