3 Attachment(s)
Re: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
The BF side bearing is only there to stop the screw whipping which does not require particularly great rigidity in the mount. This bearing should only be subject to radial forces, so as long as the mount is strong enough in the Y-Z plane it will be fine. I would make it a bit stronger than you have currently drawn, but wouldn't go so far as replicating the other end mount exactly - you can save a bit of material.
If you're buying the Hiwin rails new then there's no need to get 20mm for this size machine - 15mm is perfectly good for the vast majority of CNC routers. This could help with making the Z-axis more compact. If however you find the rails cheap on eBay then by all means use the larger sizes. You shouldn't have much difficulty finding a good deal there at least for the shorter rails.
As irving's said, recessing the motor mounts is an easy strong way to get round the short shaft problem, here's a few examples:
Attachment 6602Attachment 6603Attachment 6604
Jonathan
Thanks Jonathan... Pics really help visualise things... Looks to me like those mounts are milled down to about 3mm? Have you noticed you're missing a bolt in pic-1... or is that one an optional extra... Lol
I've drawn my pics with 20mm rails because I had already created them as components under Sketchup, but am seeing more and more comments stating that 15mm is plenty good and that would save some dosh, and might bring Z 2mm nearer to Y.
But, I am a wee bit worried about aligning 15mm rails on this particular profile as the slot itself is 10mm wide and then there is a wee surface rebate on each side of the slot, that looks to be about 1mm, which makes a total gap of 12mm resulting in the rail only being supported by 1.5mm on each side! So am thinking that 20mm would better... supported by 4mm on each side?
WandrinAndy
Yes something like that... you don't need much thickness if there's plenty of material around the motor mount surface to stop it bending. I missed two screws in that picture as it was just a test fit.
WandrinAndy
The drawings are available from the Hiwin website by the way...
You can also get Z closer to Y by milling pockets in the Z-plates for the rails and blocks. That's required anyway if the plate isn't nice and flat...
WandrinAndy
Ahh didn't notice that. With either size rail I would prefer to see them mounted on a strip of aluminium and have that bolted to the aluminium extrusion to spread the load. Hiwin 20mm linear guides are 36mm tall and the 15mm variety are 24mm tall, so if you mount the 15mm rails on a 12mm thick strip the rest of the drawing stays the same. In addition this maintains a good spacing between the 4 blocks which is necessary for good rigidity.
Jonathan
The Hiwin pdf I downloaded from Zapp about a week ago gives the height from bottom of rail to top of block as: HGH20CA = 30 and HGH15CA as 28, so much of a muchness. Are you figures for a different model or have I cocked up?
Yep, I will also need some milling done in the Z/Y plates.
WandrinAndy
Edit, sorry I accidently looked at the dimensions for HGL and completely misread the table. You are correct.
Page 6.
Jonathan
Page 6.
Ok, that looks like the same doc but I'm taking the specs from page 6 for Model Series HGH (Square type) which is what Zapp is advertising on their website currently, whereas your page 5 is for model series HGL (Square type3) whatever type3 means... Maybe low "profile"... Why oh why can't things be simple...
WandrinAndy
It is simple - if you get 15mm HGH from Zapp it's 28mm. If you get 20mm HGH it's 30mm.
Sorry for causing the confusion...
No probsh... My confusion was caused by me not realising the blocks come in that many different models.
Two quick questions please.... I'm considering again how prone the ballscrews and profile-rails are to contamination from chips etc. particularly on the X-Axis.
I'm guessing it might be prudent to get the optional bearing-block scrapers fitted to protect the seals on the X-axis, but that the other axes are far enough removed from the cutting point to not be too much of a worry?
Let's say I am machining small alu parts... would this be best done at the BF end for better accessibility and to reduce contamination, or best at the BK end that is closer to the motor?
Thanks,
Andy
As I've never made much of any mechanical rotating thingies before, the whole aspect of Timing Belts and Pulleys was a worry. But now that I've absorbed the relevant postings on the forum... particularly thanks to Jazz's pics... it seems quite simple.
I am again thinking of using RM1605 ballscrews for maximum possible resolution and torque and then gearing 2:1 to achieve "longer pitch" and speed. I understand this will increase load on, and reduce life of, certain components... but it somehow still gels better in my grey matter than doing it the other way around. Please persuade me if the other way is really the far better balanced solution... afraid I can't quite get my mind around that... yet?
On the X-axis will use 5mm pitch 15mm wide HTD Timing Belts and HTD5M-15 Timing Pulleys - 16T [o.d=28mm] and 32T [o.d=54mm] from http://www.beltingonline.com/5mm-htd-timing-belts-4575.
On the X-axis the Ballscrew pulleys will be 16T and Stepper pulleys swappable between 16T and 32T as a start :
- Stepper pulley bores modified to be 8mm and with 1 off M4 grubscrew hole
- Ballscrew pulley bores modified to be 10mm and with 1 off M4 grubscrew hole
Each idler will be made of two bearings 8mm i.d x 28mm o.d x 9mm wide from http://stores.ebay.co.uk/xtremesportandleisure-uk-online?_trksid=p4340.l2563 sandwiched between large washers serving as guides on each end.
Two quick questions please -
- Apart from asking Chai to machine F increased to say 30mm for coupling, does Chai grind the small flat on the shaft for the grub screw to grip and stop the pulley spinning or is that something I would have to do?
- Are M4 grubscrews about the right size for 8-10mm diameter shafts?
The costs are mounting... but after my massive shock at the cost of profile-rails and bearing-blocks, these components seem comparatively cheap!
Thanks,
Andy
WandrinAndy
No no no wouldn't recommend that route.? Yes I know my machine use this setup but that was purely because 1610 or 1605 where not available from Chai and at that time ballscrews from anywhere else were very expensive and out my reach. Even 2nd hand they were more than Chai wanted for new ones. Thankfully things are very different now days.!
It's always better to obtain the required speed from the using correct pitch screw so 1610 is far better option if you need the speed. Plus you'll have more torque from the motors has they won't be spinning has fast and in a much better area of the torque range while cutting which is where it matters most.
If you need resolution then you can always gear down, yes you'll lose speed but the torque will double. Still use belt drive even if your running 1:1 because of the fringe benefits of resonance dampening and flexibility to gear if required.
WandrinAndy
No it's DIY but turned portion is soft so a decent file and it's done in 2mins
WandrinAndy
Use the largest you can fit in the boss of the pulley.! If going between teeth on pulley then just make sure you sink deep enough doesn't foul belt and no sharp edges.
I mainly use M5 and M6 some times M4. Bigger the better because the larger allen key means you can get good purchase for tightening plus more surface area on shaft flat.
If you end up using 1610 1:1 then I'd use 20T pulleys has it's a nice radius and the belts aren't quite so prone to cracking from the tight radius smaller pulleys give.
