Yes Ray machine will stop and the relevant tripped switch LED turn on.
Easy to test off machine just run 5V+ wire from PSU to LED/resistor then thru NO contact of switch that Neg (-) is connected to BOB (-). the BOB will return to Ground of the PSU.
If it works Mach will go into reset and the LED light up while switch held in.
