Re: Router has died. Need Advise Please.
Jonathan
Bear in mind that ABB's recommendations for cable size are probably trying to cover themselves for most applications, whereas our application is quite specific.
Jonathan, I fully understand what you are saying but it's a bit like the DIY person who installs a new 13amp socket outlet using a bit of 3 core flex because he only wants to plug a table lamp into it. They sell the house and next owner plugs a 3 bar electric fire into it.
The supply cable could be 4 core armoured.
Eddy Do you not think that this is a bit OTT as on these type of VFD's there is not the provision to connect wire armoured cable with a separate box. I don't know of anybody in a DIY situation that would use it. Just my two cents worth:beer: ..Clive
This is going to sound rich coming from ME but come on Lads don't turn it into an argument and pyshics lesson so to confuse the Man.
Bush Flyer 1.0mm/2 is fine for these Spindles and what I've fitted many times without any issues even on heavy use machines but if you want to cross I's & Dot the T's then use 1.5mm/2.
2.5mm/2 for the VFD Input. If near heavy traffic or chance of damage etc then armoured if not then just use 2.5 Flex not ridged mains cable.
Right 1.5mm/2 cable for the spindle and normal 3 core for the mains but the size I was going to buy 1.5mm/2 cable as that can handle 15amps, and a wall plug is only 13amps.
2.5mm/2 would be able to handle 20amps but still the wall plug is only rated at 13 amps.
Or have I got to take the main feed straight from the fuse box to get 45amp supply in the house ( I hope not.)
2.5mm^2 for the VFD input is excessive. 1mm^2 is adequate...so if you want peace of mind go for 1.5mm^2!
It's a 1.5kW spindle, so anything above that and the VFD will cut out within a few seconds - i.e. too fast for the cable to heat up, so you only need to rate the cable for 1.5kW. 1500/230=6.5 amps, hence 1mm^2 (rated for 10 amps) is plenty for a 1.5kW spindle and just enough for 2.2kW as 2200/230=9.6A.
Jonathan
Didn't realise it was 1.5Kw spindle so yep 1.5^2 fine.
Clive S
It's recommended that the supply cable also has a screen so I was meaning the supply cable to the control panel enclosure which I assumed would be metal and wall mounted. Just because people keep saying it's DIY I'm not into dumbing things down. I would suggest the supply be fed by a 16 amp minimum supply, if you want a plug and socket then it's the blue type.
Right that's it sorted, I have ordered 4 core 1.5mm/2 screened and 1.5mm/2 normal 3 core mains.
Thanks for all your help, once I have it set up and I run into problems I will probably need your help again.:thumsup:
From your post #25
The VFD is 1.5kw HUANYANG VARIABLE FREQUENCY DRIVE.
The motor is a, Germany Imported Bearing, water cooled spindle 0.8Kw
I take it your spindle is 0.8Kw .. Clive
Clive S
From your post #24
Ahh, this is the point where you consider Eddy's post #31:
EddyCurrent
Jonathan, I fully understand what you are saying but it's a bit like the DIY person who installs a new 13amp socket outlet using a bit of 3 core flex because he only wants too plug a table lamp into it. They sell the house and next owner plugs a 3 bar electric fire into it.
We wouldn't want someone to change the 800W spindle to 1.5kW and potentially melt the 0.75mm^2 wire that would be fine for the former...
