Re: Thor, or should that be Zeus?
Chaz
Thanks. I did think of that - I tried to blow into it but a bit limited in terms of space. The black grommit things were removed, wasnt sure if there could be anything else blocking.
If you put a temp. tank above the spindle with one pipe to the spindle and the other pipe lower down into a bucket and siphon the water it should run freely. I take it is one of the normal Chinese spindles
Clive S
Yep, 4KW unit.
Chaz
Yep, 4KW unit.
Chaz I have not seen one of those so can't comment but the water should still flow through and I would expect you to have a bigger tank
Clive S
At the moment im just using a plastic bucket filled with water (probably 5-6 litres) at ground level. I raised it manually by hand to lower the head distance however it made no real difference. I suspect something must be blocked but the limited flow wasnt exactly inspiring either, so I need to improve that. Without the the thin tubing, the pump pushes out a fair amount of water.
Water now flowing, was completely blocked. Had to take top off and eventually got some crud out with air gun.
Chaz
I have read of many people hack their spindle, breaking gaskets blowing with air gun. Dont do that! Or do it with care as a final remedy. The good thing is that you have opened it. I did once that on a 0.8kw spindle and had to open it later...
Boyan Silyavski
Too late. There was some crap and smelt like rusty water. I dont think it was water from me, perhaps when it was tested, not sure.
Chaz
My 1.5kW spindle blocks every few months or so. I have to drain it and gently use an airline at work (hands loosely cupped around inlet so the pressure is low) to clear any deposits. I think the channels inside are pretty small as it has always had a level of resistance when you blow into it with your mouth so it does not take much to block it
I use water designed for PC cooling circuits to reduce corrosion but it does still block eventually
I'm thinking of different ways of doing the WC on the new machine under construction. Maybe a filter and maybe pumps / valves arranged so the water is emptied back into the reservoir at the end of a session leaving the spindle dry. Someone will probably tell me that it will be worse if it dries out . . .
routercnc
It will be until it completely dries out.
Far simpler option is to put some anti-freeze (or summer coolant) in, as it has corrosion inhibitors in, and will improve the cooling performance over plain water.
I was originally thinking of using distilled water (Or RO water) but water is actually very corrosive if it's pure water (Has a low EC or TDS reading) which I forgot until I read your post. Antifreeze has got to be the best choice but added to distilled water (Or RO).
Good thing about using distilled water is you should get no scale.
