Awesome and as routercnc said it sounds to work smooth,(I write that to show that I know something from cnc machines), lol,you are almost there man,carry on!!!
Getting close now... two axis moving, spindle on and spinning.
https://uploads.tapatalk-cdn.com/201...2de534db7f.jpghttps://uploads.tapatalk-cdn.com/201...7cc851becc.jpg
Hello all,
Bit of an explanation of my limit switch wiring and video of all axis now moving below:
https://youtu.be/YhuqM_D9lS8
https://www.youtube.com/user/joerharris
Must be proud of your self :) still watching your video's so well done mate.
I have been busily getting my head around fusion 360 in the background (very nice programme, can't believe they let the likes of me use it for nothing!) and sent my first programme to the machine this evening and of course things did not go quite to plan.
The intention was to cut a small pocket 55x55mm with a 1/2" router bit (12.7mm)
This was all set up correctly in fusion (I think) and it cut fine, albeit far too slow (I'll up the feed rate next time around), but the problem came when I measured the part - see pictures below... any ideas!?
After all this time building, it is dawning on me that I have no idea how to use this new tool of mine :(
Edit: Sorry - pictures make this look worse than it is as I forgot to zero the calipers! I'll take some new pictures...
New pics after previous post - prob need to run the calibration wizard in the settings window of MACH3 again... but being out by 0.8mm in one direction and 1.4mm in the other does not seem a great starting point.
https://uploads.tapatalk-cdn.com/201...5d826cdea8.jpghttps://uploads.tapatalk-cdn.com/201...8957793e72.jpg
Joe don't get despondent, this is normal when first getting the machine calibrated. Check it over a greater distance say 300mm in fresh air ie. in the midi type g1 f500 x300 and check to see if it has move exactly 300mm then do the same on Y ie type Y300 and check that. you might have to amend the steps per.
Hi Joe, good to see your machine is moving, albeit not as accurately as it should! I've been using my machine for a while...as you can see from the state of the bed (sacrificial) I still make mistakes. Every day is a learning day [emoji16] [emoji106]
Hope you get it sorted soon [emoji106]https://uploads.tapatalk-cdn.com/201...88acf49b0b.jpg
No big deal.
Like Clive said you run the calibration and Mach 3 asks if the axis you calibrate,each time,moved at the distance you want,you put the correct distance in the proper box and you see the machine do the correction!
Nice to make the first cut , especially with a machine you build, right?
