Jonathan
At first glance I thought that, but he's using such excessively thick wire that it's probably not a big deal.
It's wire I had left over from making Y leads for my large electric RC Helis, I though it would be good to use as I could strip sections of outer off, push it over the pin and then flood with solder. Then cover the soldered bit with hot glue to insulate....
Missed that first time round, nice idea looks cool.
Not sure on Clive and the chocblock, I guess he's right but what to do...
I guess you need somthing of a busbar, mini consumer unit? Or is that ott?
.Me
Maybe mount the MCB's on the din rail with a busbar and then a seperate din mounted busbar for the -ve?
:) sounds like a plan :), just seen these: http://m.ebay.co.uk/itm/321061386290
I remember now...EddyCurrent linked to that in his build...looks like a good solution, ta!
Lee Roberts
These seem ok and you would get the fuses for the drives (if you want them) you would need two of them fuse in the +ve and bridge the -ve solid (no fuse) cheapo choc blocks will melt if the screws come loose. Clive
ps the others with the led in would be no good as you will be running 70V ish.
Clive S
Yea i think the white version are the better ones, somthing about not melting.
How about soldering the 1 wire from the caps directly to 3 smaller wires and connecting them to din terminals.
http://tapatalk.imageshack.com/v2/15...3279bf4b7e.jpg
Then connecting from there to MCB's before going to the drivers?
http://tapatalk.imageshack.com/v2/15...f26a3810fd.jpg
