Hi Daveo
I recently bought a Novusun NVUM controller and I am struggling the same as you to get the outputs working correctly. Did the supplied solution work? What did you end up doing?
I'm also looking at switching a relay to start up a dust collector and water pump, would this wiring be the same as for the spindle setup to activate the relay?
Any advice to an electronics novice would be greatly appreciated!
