Re: Rye Quantum First Start... Drive Fault
If you don't want to shell out for a new post processor and you aren't so deeply immersed in an existing CAD/CAM system and control software then might I suggest you take a look at LinuxCNC?I believe Fusion has a post processor that will work with it and I know that Freecad does because thats what I use.I have to admit that I have seen Vectric software and it definitely goes it's own way with terminology and general approach.It does work and it isn't hugely expensive,but either Fusion or Freecad will do the job at zero cost.
routerdriver
Interesting... I'm not familiar with LinuxCNC… does that need a controller swap out etc or are you saying it will run through my existing one?
BEACHBLANKET
To vastly over simplify,It will run all sorts of machines once you have explained to it how many steps/unit of travel.For my hobby machine,on steppers,it was mostly a case of finding out how quickly the computer that runs the machine could churn out pulses,estimating an acceleration rate and determining the number of steps per rotation of the ballscrew and thus from the pitch,the steps/mm.There is a forum abundantly populated by experts at https://forum.linuxcnc.org/.They will be better able to answer specific points.You can download it and run it live from a DVD or a memory stick before committing to an installation.
