Re: Upgrade? Chinese CNC Machine
Carlb1058
			Just a tad - cheers :) I ended up with 409.62 using 3.175 as the tool diameter
 Once we have got both axis to move the same amount i can do the math again and give you the imperial equiv, then we can change the system to old school as like swarfing said it could be a yank model. but we will get it for you then of course that will rule out the mechanical and software stuff as the source of your trouble, leaving only the electrics but they may be fine and just need proper BOB and stepper drivers should you be so inclined..
Rick
Carlb1058
			Yep 3 to a cm the biggest problem with trying to measure the X is it is fully enclosed and I'd pretty much have to tear it apart to get to it but I shall attempt to get a close as damn first :)
 Dont bother it can be worked out with the software al be it a little long winded..
Rick
Carlb1058
 well that was easier than expected, managed to get a 1cm wide flat file between the frame work and as near as damn the X is 3 turns as is the Z, so all the screws are the same size
		confused but could be possible?
 7.26TPI 	0.13774" 	3.499mm pitch is about as close as you could get to that. Stick with tuning it out for now like Rick said before. Imperial or not you would still like it working with what you have. Sorry i took this away from that.
Swarfing
 No drama, it's always good to learn new stuff :)
		Got to hit the sack, hope get somewhere soon
Paul
Swarfing
Paul
 Lightweight...LOL
Rick
NN mate
Ricardoco
			Lightweight...LOL
Rick
NN mate
 Looks like im a lightweight too Im off to bed as well, speak tomorrow Carl
Rick
Ricardoco
Rick
 no problems - all the help so far has been great
		Why not get Mach to do the work for you ? go into "Settings tab", just above the reset button "set steps per unit" start with X enter 100 measure how far it moved then tell it how far it moved and will set steps up for you.
Do the same for all axis do a test cut if not correct go though it again.
Phill
