What is the best way to Test a chines machine?
Hello everyone
I purchased a CNC router 1325 From china.
I want experimented users to advise me what tests can be the best to know that the machine gives good results and work properly.
It appear very good but I want to ensure.
The machine is still on factory and I want to ask them to test it more.
Any other advises are welcome. ( I don't want to have troubles after having it)
thank you
Re: What is the best way to Test a chines machine?
When you say test it, test what, do you mean the accuracy when cutting say a circle for example
Thank you Kev2960 for your replay
I want to ask video tests from the manufacturer and I have no Idea what is the best tests that lets me judge that the machine is good and accurate and give best results.
Also what are things that can you advise me to ask about, before shipping the machine?
Thank you
What do you intend to use the machine for
Kev2960
In first place for advertising.
can't you just send the company one of your products to be cut
Is it possible to send me a link to their web site
cnclover
Hello everyone
thank you
Cut a square check it looks square and measure it.
Cut a circle and check it looks circular and measure it.
Repeat the above with the materials and depths of cut the machine is advertised to be capable of and ensure the results look neat and measure correctly.
Kev2960
yes with pleasure.
The company is OMNITECH.
It seems good.
http://www.omni-cnc.com
magicniner
Thank you very much
I will do.
cnclover
Hello everyone
thank you
So you have the machine or you dont yet?
Advice from buying from China is be weary. I purchased a cheap chinese laser cutter off ebay and it was pretty rough but does the job. My experience with routers from China is pretty limited but make sure you do proper research on youtube before you even spend a single dime
