Help Please my web is broke
Help please; Somewhere in UK there is either a blacklisted server or a broken link to my website www.cnc.me.uk
This is not a request for loads of visitors but I would appreciate if you can look to see if you can access my site, if you can please email me roger.hampson@(antispam)btconnect.com (remove antispam) giving your isp and county, I do not want to know who you are.
but more importantly I need to know if you cannot see my site as I can use this information to blast my isp into doing something about it.
Please uk only
Dear moderator, this is a genuine request, I apologize if it is in the wrong place or if it is against the rules, but I cannot see my own site, and I cannot do anything about it unless I can draw a map showing blackout spots:mad:
Re: Help Please my web is broke
cncezee
This is not a request for loads of visitors but I would appreciate if you can look to see if you can access my site, if you can please email me roger.hampson@(antispam)btconnect.com giving your isp and county, I do not want to know who you are.
Please uk only
Well I can see it OK... but then I'd be surprised if i can't.
What do you mean by 'I cant see my own site'?
BTW I have edited your post to 'antispam' your email address
Sorry why would you be supprised not to see it??
Oh and Thanks for editing it
If i try to view my own site it times out i have tried several places with differand internet connections but it still times out, my freind 20 miles up the road has no problem accessing iti can ftp it but i cannot see it, it is not fire wall this end as i can see the rest of the world, just not my site, i do not want to movas it is hoasted for free
Cheers roger
I have no problems accessing it from Surrey, and also from a hosted machine I have in London.
Are you running it on your ADSL line? I've done a reverse DNS lookup, and it would appear so, but I'm not sure what the Virgin Media naming scheme is...
Sorry i do not know what line connection is being used but it fast enough for his business, ping reply is switched off at his server
Are you trying to access the site from the same location as you (i.e. is it in the same building)?
Or are you somewhere else?
Just seen your edit.
On my office machine, it did seem to have a fair delay between requesting the page and getting a response, but that's using a leased line, and I don't think there's anything special going on there. (I could do a TCP level packet inspection, but I don't think that'll tell me anything useful [from your perspective]).
Hi Tribbles who is your isp??
No the server is in west swindon i am about 4 miles away, it is looking like it is a fault with our major uk telephone company
Works fine from here in bournemouth.
I am on Virgin cable.
What is your service provider? have you tried to view it as the IP address in your browser?
My home ISP is Zen; office is Pipex (I believe); hosted server in London is Bytemark.
ANY information Anyone can provide will be usefull
Yes i time out nomatter what connection method i use, the IT engineer who is running the hoastin is as baffeld as i
It's something that I think would need to be diagnosed on your computer. I could talk you through some fairly technical software that analyses TCP packets - that could provide some clues as to why it's not working.
But, it is fairly technical.
Is the IT engineer seeing the requests coming into the web site (i.e. are they being logged)?
It would seem that people on virgin have no problem Just me on BT and in and around swindon
I'll just see if a mate of mine who I think is on BT is about (and can have a go)...
The web stats show large usage from most of the world, it is a very local problem, if it were my modem hooked up or somthing i could restart it and fix it, but if i go to my works location 3 miles up the road with a BT connection i still cannot see it
He's having no problems with BT in Portsmouth.
Do you know your own IP address?
I applogise to MYCNC for aring this out here but i am lost in how to fix it
Yes 81.109.86.250
Just connected with ftp pro no probs but still no site
So FTP works and HTTP doesn't - is that right?
Sorry - I meant your BT IP address (I already had the website IP address :smile: )
Which web browser are you using?
direct ip lookup timed out
I have explorer 7, and i have just tried firefox
Do you know if you are using a proxy to connect?
my current ip address is 81.156.92.249 and what do you mean by proxy
A proxy is used as a gateway between machines, and can speed up communications, or allow you access to sites that can be otherwise unavailable.
However, misconfigured proxies can also block access to sites - but still allow other communication methods to pass (such as FTP).
It might be worth taking this discussion off the site (it could go on and on) - you should be able to send me an email by clicking on my profile.
cncezee
Cheers roger
Roger,
Where is it hosted? I've seen your site before (when i was researching casting) and not had a problem accessing it before. Has this timeout problem started recently? When you say 'from several places', do you mean on the same ISP?
Timeouts are often one of the following:
- most commonly, a DNS problem. From a command prompt, if you do 'nslookup cnc.me.uk' do you consistently get your IP address 81.109.86.250 returned OK?
- a reverse routing problem... your request gets to the site but the response doesnt get back to you... If you can FTP to it do you have access to the traffic logs... can you see your own requests getting to it?
Wow, Sorry guys, first i attempted to look at my site and got lost on page 3, now having relised you all had goe on to 4 i was left behind
Tribles no i am not using a proxy it is purly an internet connection, yes i am happy to end this here and call you if that is ok with you?
Hi Irvin, if you look atwwwdotfmssltddotcodotuk this is where i am hoasted dots removed the problem seems to have materilised arounf the turn of newyesr when i changed isp from tiscali to bt, sure it may be here but that again points to my equipment, but i get the same prob on other companys equipment too
Hi Irvin2008, how do you do an NS lookup?
Roger
Roger,
Have you tried accessing the other sites they host: http://www.fmssltd.co.uk/websites.html
Do you get the same timeout?
I also didn't realise that my posting had spilt onto page 4 (took me a few refreshes to spot it).
Can you access that Fusion website now?
Anyway guys, this is all very well and i do apreceate all of your help but this is not realy what i need, what i am looking for to do is to complie a low level map of who can and who cannot and where you are, as i have loads of stuff to put on my site when i can see it
It's very important: Can you access the fmssltd web site now?
(Hint: it's the same IP address as yours).
No i cannot see anything from that server
Okay - that rules out it being a content problem, and is more of a firewall/proxy/network connectivity problem.
