Just before we get the scrap man in to top up our tea fund i thought i would see if anyone thinks there may be something of use to them, mind you its damm heavy stuff :-)
Attachment 29619
Attachment 29620
Attachment 29621
Attachment 29622
malc
Attachment 29619
Attachment 29620
Attachment 29621
Attachment 29622
malc
What are the circuit breakers
Are they suitable for a cnc cabinet?
The e stops look handy as well
Also what is the transfer in the front of the first picture any voltages on it
Cheers. Paul
Are the black motors with the ally on the end stepper motors and is the ally part some form of gearbox ?
If so I’d be interested in a few of them
Had a look online and can’t find any info on them
Hi Paul
E-stops will do perfect for this type of work
I will take some better pictures for you tomorrow so you can make a better call than me for the other bits
And yes that is a gearbox on the end of the stepper motor and no i dont know the ratio :-D
malc
Excellent. Cheers. Paul
What is the frame size of the steppers Bernie?
And how long before they go in the skip. I know we are locked down but I can go out to fix appliances, so If your works heaters need attention I could visit.
:sneakiness:
And i am not fluent in itallian Paul but could Giri (on the plate ) indicate the ratio
That’s a good call john
In which case these would be excellent for a project that I have in mind
Paul
I can put anything aside for as long as needed to save the scrap man :-)
So frame size, i am really sorry but not sure i know which bit to measure.
Attachment 29631
Attachment 29632
only 4 of these
Attachment 29633
Attachment 29634
malc
Hi Malc
The nema flange designation would be the size of the square flange in inches so looking at the ones with gearbox I am guessing from your caliper Nema 34 and I would like a couple of those if possible .
https://www.kollmorgen.com/en-us/dev...ma-frame-size/
Difficult to see if the ones which you say you have only four are bigger or smaller but the square size of the flange would tell us .
E stops? yes please
Breakers? yes please
Are there any distinct drivers or are they incorporated into the machines boards?
Anything there that looks like a power supply? I certainly see transformers both toroidal and conventional.
Am thinking that the it would be good to have the opportunity to have what in Cumbria we would call a "ratch".
For those who do not understand our lovely dialect I am thinking of a rummage amongst the contents of the heap ,
Thanks Malc
but those dimensions sound odd
Did you remember to zero your caliper ?
mmm good point, will try to get in another check :-)
Attachment 29635
Attachment 29636
malc
So we have nema 23 and nema 34 . and a bunch of other stuff which loks interesting. Will Pm Bernie
