AXYZ 4008 meltdown due to stupidity!
Hi Forum
Does anyone have an "AXYZ_OS.IMG" file to reboot for OS 9.71 AMC
My recently bought (very old) 4008 has an AMC contrtoller.
I managed to actually import .DXF into TPWin and cut a couple of perfect parts.......THEN...
I wanted to use the AXYZ DNC iinterface in order to use Aspire .nc files direct to the machine. I also got a post processor from another forum member to save into.
When opening the DNC interface it said "no connection". Opened the "port settings" and hit the "boot OS" button....Might as well have hit a nuclear launch code....!!!! Now my machine is all over the place, running past limit switches, the gantry almost ran off the back of the table!! Did a "system restore" but the machine still won't revert back to original table parameters/config.
Any help would be greatly appreciated as this is my main source of income.
Cheers Kevin
Re: AXYZ 4008 meltdown due to stupidity!
My recollection is that AMC/DNC are both interfaces that run on top of the parameters you enter in the Toolpath software.My memory is telling me that DNC means that you are running the program from the computer linked to the machine and not using the AXYZ controller and this may mean that the computer has no idea what the limits of the machine may be.I really hope you had a hard copy of the values that applied and a copy of the installation disks as this may be the only way back.I suspect that an AXYZ tech could salvage the situation at a price.This would be the last resort from a financial point of view.With the disks to install the software and drivers for an RS485 it isn't that hard if,and only if,you have all the parameters recorded.I would suggest sticking to AMC file transfer unless the controller has utterly minimal storage and deleting any unnecessary programs in any event as it can be a bit time consuming to scroll through a huge list.I will deny any knowledge of a 4008 as I had experience only with a 6010 but the similarities are considerable.
Like Routerdriver says getting your hands on the disks or software isn't going to do you much good if you don't have a backup of the parameters, highly likely it will just do a default install, then you would load in any parameters which relate to your machine.
This is why the machine is all over the place now after you have overwritten the OS, it has no clue about your setup. doesn't know which pins the limits are connected to, etc.
Even an AXYZ engineer won't know all of this without getting into the machine and checking connections etc unless they wire them in a standard way.! Possibly does but could easily not in which case he'll highly likely try to screw you big time. For instance.!
We have an old Hurco Mill and the Hurco Engineer wanted £55hr from the minute he left his house to getting back home, he lives 200miles away so it's the best part of £400 before he even touches the machine.!! . . . Hence we repaired it our selves. (well actually we ripped its guts out and putting a modern controller on it)
Do the previous owners have the parameters written down or backup disk maybe.? Or, Sometimes the main parameters will be written on a sticker inside the controller, maybe on the back of a door or panel.? Worth a look.
If it's going to cost you a lot of money to get an engineer out I would seriously consider retrofitting with a modern controller which runs from PC-based software then you won't have any of this DNC rubbish to deal with. I know someone who has converted a few AXYZ machines to run on UC300 controllers with UCCNC software and it's not difficult to do and transforms the machine and reliability.
did you get up n running?
ive retrofitted lots of axyz. all working well now.
All sorted and thanks for the input. Managed to get OS booted and correct parameters and configuration from AXYZ and assistance from a guy in Canada who has the exact same setup!
BespokeR&R
i have an assortment of good axyz boards pulled from these if you ever need anything- at a lot less than axyz prices :-)
eg. https://cncrouter.uk/used-equipment/used-cnc-parts.htm
Looking to add atc and also remove pressure foot and replace with brush shoe...
Gimme a call when you get a gap
Kevin 07999048152
BespokeR&R
Hi Forum
Cheers Kevin
if you still need the software, let me know, i have all of the OS's and programs
t8r007
Hi can you please message me the software please. I have a 2008 axyz 4008 that I'm trying to get running.
iiDunno
You will have to accept private messages for that to work.
I have an AXYZ router in Australia.
I'm replacing the driver with a generic driver as the original driver is 32x the price.
How ever I cant get into function 18 to set the drive type (assuming installer settings are locked to user level).
Does anyone know how to get to this function ?
Milom1972
I don't think function 18 is what you want. its only the for setting the operator preferences. nothing to do with the replacement of parts or software. funny enough, its the function that locks down operator access. i will tell you how to get into it though. if its on level one, you have to enter code 7758. if its on level 2 the code is 1954. If those dont get you in then i would wipe and reinstall the OS on machine. its not hard to. function 159 deletes it for you and you just load another one through toolpath or the DNC. Use function 29 to get the OS info before you wipe it. would also be good to get the info stored in machine personality in either toolpath or the DNC.
what driver are you replacing? a motor? board? software? its hard to say where the solution is if i dont know where to look. it sounds like you need to get into either toolpath or the DNC and look in Machine personality. OR, you need to replace the OS on the machine with one that uses a similar driver to whatever it is you got. OR if you replaced whatever it was with basically the same thing. you might just need to calibrate the machine which i think is also in that personality place again, OR use functions 603,610,611,612,and 613, to recalibrate it. OR i could be way off... but don't worry, there is A LOT more from where all that came from. for just one more OR.
I would be willing to upload the AXYS AMC (not A2MC) disc that has everything all of you would ever need for these machines, but i cant find anywhere on this site for uploads. it has all the operating systems, all the drivers all the DNCs all the labs, all the functions and error codes with explanations and if you've never had the joy of working with ToolPath it has all of them as well. and the 388 page training manual, and 72 pages of wiring diagrams. CNCzone does have an upload area, but it does say Open- source and AXYZ is definitely not Open to any source but them. Any suggestions?
he would be fine to erase the the Operating system intentionally if he wanted, its Function 159. the parameters and settings are stored in both the DNC and toolpath, they will be there when he reloads the OS through either of those programs. ive swapped in different OS's more times than i can count. the one my machine "is supposed to have" conveniently didn't have function 22 reinstalled on it. so i just switched back and forth. all you have to reset is Function 330 if you have an Smouse.
Dont retrofit, there is no point in replacing quality parts and durability with new parts just because the machines are simple (also adding to that durable thing) with complicated new ones that have to be modified to work with your machine. if i could upload the disk somewhere i will. AXYZ still sells the old AMC software disc on the cncshop site. its a hundred dollars. i bet thats a whole lot less than replacing things that arent broken with stuff that will be obsolete in ten years anyways.
edit: the disc is 200. still a better deal.
t8r007
Thanks M8. ive created another post so i dont overtake this one. mine is a AM2C i hope you can help. thank you in advance.
