13 Attachment(s)
		3 Axis CNC Router for Sale - Steel Framed, Machines wood/plastic/metals
		Hi all,
As I'm busy with work and no longer have the time or space to run this machine, i'm looking to sell. Would alo consider selling parts seperate (control panel as a single unit), if there's more interest. Details as follows:
General Info:
Hours of use: Few hundered hours of hobby use (many of which were idle)
Materials cut: Aluminium, brass, various woods, foams, plastics and more.
Cutting area: ~700 x 400mm with Z axis of around 90mm (from spoil board (18mm thick) to spindle). There is also a 100mm overhang for taller objects at the front, so total ~800mm X axis.
Machine construction:
Components:
- HIWIN 20mm rails on all axis (1000, 600, 300mm)
- 1610 dual ball screws on X axis (1050mm long), 1605 single ball screws on Y/Z (650, 250mm)
- All ball screws are belt driven
Materials:
- 4mm thick steel box section for the frame/gantry
- 10mm steel gantry side plates
- CNC machined aluminium Z axis and motor mounts
- West System epoxy levelled rail base on X axis.
Electrics:
- 2.2kW Water cooled spindle + Huanyang VFD
- AM882 digital drives on all axis
- CSMIO/IP-M motion controller
- PSU for drives + axillary PSU for others
- 8.7Nm NEMA 34 on X axis and 3.1Nm NEMA 23's on Y/Z (all CNC4YOU)
- Shielded cables used throughout
Additional:
- Mach3 license and setup files to suit this machine (can consider selling laptop too)
- Manual valve controlled air blast setup for metal machining
- 25L coolant system setup for spindle
- Proximity sensors on each end of all axis for homing and limits
- Various E-stops on the machine/control box
Can also sell
- Various size aluminium plates
- Various tools/collets for the machine
- Workshop tools (Drill press, bench grinder/sander, compressor, vibratory tumbler, ultrasonic cleaner, etc)
Photos:
Machine:
Attachment 31631Attachment 31632Attachment 31633Attachment 31634Attachment 31635Attachment 31636Attachment 31637
Some machined parts:
Attachment 31639Attachment 31638Attachment 31640Attachment 31642Attachment 31641Attachment 31643
Located in North East for collection, if anyones interested. Thanks
		Re: 3 Axis CNC Router for Sale - Steel Framed, Machines wood/plastic/metals
How much are you wanting?
Wylie
 Hi, trying to send you a private message but doesnt seem to be working. Will see if I can get it sorted.
Wylie
 Looks like it's your settings.
Could you please check and send me a private message when able. Thanks.
		Hi also interested in price thanks Sam
		Hi, I’m also interested in the price, thank you.
johnpaulcarter
 Hi John, please could you private message me to discuss. Thanks
		This is still available.
Looking for around £3,500 for the CNC, collection only — open to offers and would consider selling parts seperatly too (full electrics, frame/gantry, etc).
		Edit: Managed to sort storage for this, so availability is now TBC.
raj221
			Hi all,
This is now available as could really do with the extra space.
Cost me quite a bit more for the components alone, so think it's a fair price. Thanks
 Bargain price. Hope you get a sale sorted soon.
		Still available if anyones interested.
		Looking for a quick sale, as planning on moving home — price reduced to £2,000.
Please let me know if anyone's interested.
		Still available, now £1,500.
Can sell parts seperatly if there's more interest.
		If I was in the UK, I would grab this quickly Raj, but sadly shipping it down under would be prohibitive.
raj221
 PM Sent
