Re: Z axis motor 'lifting'..
		the stepper will get hot when powered and not moving, as it's being held in position.
		Hi i2i..
Forgive the newbie questions, but is it simply that a hot motor will drop steps or stall? Think that would be easily fixed if so..
Steve..
		The Z motor must have been moving a bit though for a cut program of that length in time...I can't imagine that it was at the same depth for 2.5 hrs?
But yes motors do get hot when stationary as current is still passing through them to keep their position locked & stationary.
As for the Z axis being off....there could be lots of reasons - something in the code that you missed, something mechanical in the Z drive train that could cause it to bind in one direction, interference in cabling could cause dropped steps...& probably many other things as well.
		Hi Crafty..
Yep, 2 hours of flat cutting before the z axis has to start moving (0.01mm cuts).. Bit extreme I know, but I figured I would get to see any of the problems by cutting this part this way.. Will fit a heat sink and fan later, then do some proper testing to check it out properly..
Steve..
		Bloody hell ....a 6 hour cut? I go purple & cover the dog in spit if my simple 5 minute cut has a problem half way through - I'd need valium & a bottle of Vodka if doing a 6hr cut.
		hmmm... if it was a lot hotter then this suggests it was being overdriven (wrong current limit) or was in a state of stall (mechanical binding)  All the motors are permanently energised so should all get to roughly the same equilibrium temperature.  At high temperatures the motor could lose power (magnetics lose force with temp) and therefore a 'down' step could miss-step so the returning  'up' step is too far up... hence the decreasing z-depth over time...
The cutter you were using was a plunge type?  you weren't trying to plunge something with no cutting tip? that would stall the motor or at least make it work hard...
		Good flippin grief...
It was the power lead to the spindle, got snagged on a burr on a piece of aluminium at the top of the z axis.. Sorry guys... On the plus side, when I do make an appearance on this forum, I do seem to make you all sound like geniuses!!!!
Going to have my thumb surgically removed from my ass before seeing if I can create another 'high tech' problem..
Thanks all..!
Bonehead..
		If only all problems had such a simple solutions, :wink: ... Mind you then the resident geniu (is that the plural of genius) on the Forum would be sat there twiddling their collective thumbs!!:whistling:
		something else to also think about is connections. The motor will get hot if the windings are not receiving equal current.
		Hi Ze0paz.
After the first debacle and your compelling point, am going to go right  through all the wiring and give it a check and a tidy up..
On a really cheap note (done this whole thing on the cheap), has anyone  tried using pipe lagging (the foam tube type with a slit down the  length,) as a cable tidy? Dead cheap, very light and flexible.. Gonna  get a bit and try and try to set fire to it today, unless someone knows a  compelling reason not to (excluding pyrophobics)...
Steve..
		Steve
Get down the pound shop or ikea and grab the stuff used for tidying up the tele cable clutter??????????? its a pound
