Re: Wood Lathe - fitments
		Looks home made to me, it doesn't even have a bed as such.
It's probably been built from off the shelf components like a Picador spindle, that rusty drive centre looks like it's been made from an ordinary nut. can you unscrew this and measure the thread under ir ?
		That is possible, the bed has been sawn in two to accomodate bannister rails!! It is rusty indeed but not beyond recovery (I believe) to a mad person like me who likes getting things working! I have dismounted the lathe at the moment and the nut is awaiting the WD40 to work so I'll try what you suggest and post back. Many thanks.
		This definatly homemade,you can tell by the crude nature of the thingand the pillow blocks look new.
SGS is probably just the initials of the person that made it?
		In that case should I look for manufacturers names on the pulleys and chisel post to get a clue about replacement parts  etc.? Or are there companies which sell parts for a "build-your-own"?
The lathe was kind of free with a 4' X 2' bench which also had a (now repaired) Record No. 52 vice - all for £7.50! so I don't mind spending a bit to get it going.
		The best people to advise you on woodlathes are ones that use wood lathes....
http://www.ukworkshop.co.uk/forums/
		I'll try the other forum then - I thought this was a forum for both wood and metal working - ooops!
		You don't need a faceplate unless you are bowl turning, although even that that is quite possble without. What you do need is tailstock, a centre with prongs around it and a rest to support the tool.
Top tip for wood turning is cut, don't scrape. Rest the tool against the wood, high enough that it doesn't cut, bring it down slowly, as soon as it starts to cut that is the right angle :smile:
Robin
		Well it is but mostly CNC and metalworking but wood does come intothe equasion when routin in wood. :-)
GeorgeD
 Speak for yourself, I'm a fully qualified wood turner, 3 years at the London College of Furniture :beer:
		Ok Robin...don't bite me head off. :wink:
Its like someone going into a Fruit&Veg shop and asking for a pkt of band aid plasters. :wink:
		Thanks for the replies - this is great! Robin - I do have a tailstock which is on the other half of the split bed, includes adjustment and centre, my interest in the faceplate was to have a go at a small bowl as a trial piece so I guess I need to get the diameter of the thread as was suggested. Thanks for the tips too, it is 40+ years since I last used a wood lathe!
GeorgeD - thanks too - I will peruse the forum further with interest.
		Your lathe was obviously made by someone with a Picador catalogue, very possible a Picador spindle, you may find the thread size is in there, fittings may be available :smile:
		Assuming right handed turner ...
I use the 45X45 method with my bowl gouges (fingernail grind)
1 Tool tip on centre line with toolrest as close to the blank as possible
2 Angle handle end of tool 45 deg away from your body
3 Drop handle end of tool 45 deg downward
4 Move the tool in until the bevel rubs the blank, gently twist tool anticlockwise until a very small section of the cutting edge starts to cut ... tooling must be 'scary sharp'
Others may use differing methods.
Wobblybootie
 ... and you have to advance the tool as you head for the centre.
Fortunately, it takes so long to do your first bowl you will be an expert at this before you get to the finishing cuts :smile:
Don't be tempted to go thin, it will split when it dries out. If you really want to go thin season it some more after removing most of the wood.
		I had a look on line, looks like Picador are mainly into polishing machines nowadays, I guess some parts are the same - car boot here we come!
