i have had to buy a new pc (faster) just for cnc.
i don't want to have to put mach on it and set it all up again.
is there away round this?
Hi Chris
You can copy your profile XML file over from your old PC to your new one, but you still might have to retune your motors.
Andy
you could for reference go into the original config screens and print a copy of them just in case the xml didn't configure correctly, at least then you would have a record of each setting.
Chris
You can print your XML file off and yes it will set all your I/O inc your motor pin config.
Andy
thanks andy i will let you know how i get on.
Hummm, thinking maybe a quick little tool to back up and restore the MACH file(s) maybe in order ?
sounds good to me.
It's already been done
http://www.kd-dietz.com/klausphp/index_eng.htm
Goto software, downloads, MachProfile
It lets you backup, and even compare two profiles.
He makes the best Mach screen designer. MachScreen
Also a very good video plugin.
Phil
Sent from my HTC Desire using Tapatalk
When you move Mach, as others have said, all you need do is copy the profile (XML) file.
The other thing, not yet mentioned, is your license file (you have licensed it, haven't you?).
A further bit of good advice I've seen is to copy these two files to a USB stick, put it in a ziplock bag and tape it inside the PC or even onto the machine somewhere.
backed up on a cdr (cheaper) cheers djc
