hi all. i'm looking for a good type of screened wire to use in my drag chains when they arrive. i've looked at the cy series of screened cable but some websites say it isn't reccommended for drag chains whilst others say its ok. opinions please
Chip and I have used it... his is in a drag chain. No problem so far as I know. It would be hard to tell if the shielding is breaking though which I suspect is what could cause it to fail.
CY is ok for drag chains but does suffer from breakage over time. I have replaced loads of the stuff over the years. Give it a good stretch before you install it and make sure it is firmly secured at both ends of the drag chain so that it doesnt pull itself into the drag chain and start to coil up with the repeated movement. Also be careful
about how you unwind the cable before installation. Roll it from the drum so that it doesnt twist.
Ian
Probably stepper motors ... it generally is here.
I thought that twisted pair only helps with interference if used with differential signalling where complimentary signals are send down the two wires and the difference detected?
Will it stay properly twisted in the drag chain?
Why would anyone want to screen a stepper motor cable?
This reeks of urban legend, a bit like choosing your motor purely on holding torque :heehee:
I'd say lots of square mm for minimum resistance and lots of strands for flex.
I use twisted pair for signal cables and you don't need fancy drivers to reap the low crosstalk benefits. Even humble RS232 at 9600 is good for 100 yards in good old Telecom twisted pair, doubt you'd get 25 with screened.
So you can listen to the radio whilst the machine's running of course!
If I don't ground the shielding on my motor cables the radio (not digital) hisses a lot etc ... with the shielding grounded it's fine. I've never been able to detect the shielding making a difference to the motors.
Recommended sources for plastic drag chain?
ebay ebay ebay
I would say ebay but IGUS UK has prices that compare directly with most ebay sellers these days. They can require about a week lead time as for the most part them seem to be a front office for Germany. It all depends on size and whether you want the opening variety or not. Good luck.
Michael
