Re: PCI parallel card / BOB
Most decent BOB's have a charge pump circuit built into them to stop such as this happening by not letting any signals thru untill the control software sends 14khz signal taking control. Some BOB's will let you turn this feature off so could this be turned off.?
What Bob is it.?
I know Mach uses a charge pump, does EMC ?
John S
Yes I believe it does John but could be wrong I'm Mach thru n thru but I'm pritty sure I've seen references to charge pump and EMC on CnCZone.
2eOpoz now it's your turn to shine as Guru . . .Cmon Guru show your self. . .:lol:
I always wondered what a charge pump was.
This is the BOB, though I don't see a reference to charge pump : http://www.slidesandballscrews.com/pdf/ZP5A-INT axis interface board manual.pdf
I can give Gary a shout & see what he thinks.
I just checked the online docs for EMC2 & it is configurable for a charge pump :smile:. Bet you it turns out the BOB isn't! :cry:
Just found out, no charge pump.
Plan B then :naughty::naughty:.....
Various people sell just a small charge pump board as an add on.
http://www.cnc4pc.com/Store/osc/prod...products_id=51
Cheers john,
That looks like the best option!
Gavin
Let me have a look round as i may still have some kicking about
John,
Thanks for that. I'll hold off then.
John S
Artmin also spotted it shows how to set the charge pump inside EMC.
http://www.linuxcnc.org/docs/EMC2_Getting_Started.pdf Bottom of page 19
