Re: Single Flute vs. Ripper
Probably just the same as it is in steel or aluminium.!!. . . . Inferior.
I could have actualy tried it for you with that exact cutter but I snapped the bleeding thing while cutting 3mm box section and wasn't impressed with my self.!! . . Woz Being greedy and lazy I should have known better. :redface-new:
For low spec jobs I use cheap router bits from toolstation - it is only £1.20 a piece - worth to try
I use 3 and 4mm for acrylic and mdf - if it brakes - no problem for this price it doesn't hurt at all. So far I have nothing to complain about them.
So could I, except there's a 98kg sheet of aluminium waiting to be cut and somewhat in the way on my router at the moment!
wiatroda
I used to get those but they never lasted long and where nowhere near as fast as the 6mm single flute carbide cutters. Get yourself a few ... I guarantee you wont regret it. It's a HUGE difference.
HiltonSteve made a post in his build log on a few cutters and detailed his findings on each, he worked with ali but it maybe of intrest to you:
Link: http://www.mycncuk.com/forums/showth...ll=1#post17636
.Me
Jonathan
I got some carbides from chinese shop - not ebay- I don't remebmer shop or website name - it was somewhere on this forum - crap, crap , crap, they brake at acrylic or aluminium - I did try few sizes and was very disappointed. Then I decided to go to toolstation and I don't regret. So far I cut few sheets of acrylic 3 and 5mm thick and some 9 and 18 mm mdf from wickes with great success. I wouldn't pay at least 10x more for cutter to cut so low spec jobs.
The cheap 6mm SF 5 for £20 something quid of ebay are excellent and the don't break very easily. I've only broke 1 and that was trying to cut that really hard resin impregenated MDF in 1 pass 13.5mm DOC @ 7mtr/min after it had cutt countless jobs in Ali as well has 1 pass 10mm DOC @ 5mtr thru same resin MDF. It was well shagged and had every right to give up the ghost. . . . . IMO they are spot on and worthy every penny.
The cheap 6mm SF 5 for £20 something quid of ebay are excellent and the don't break very easily. IMO they are spot on and worthy every penny.
Jazz do you know the ebay auction to buy them from?? I must find the name of the shop of the crappy ones I bought from china-them ones which you wait for 1 month and they brake in 3 sec :/
Yep it was " SUPER MARIO" . . thou it looks like they have gone up, sure I payed less than £25
Edit: Yes I did pay less just checked payed £21 + 5 del
http://www.ebay.co.uk/sch/supermario-au/m.html?_nkw=&_armrs=1&_from=&_ipg=25&_trksid=p3984 .m1439.l2654
I had some carbide cutters from china that broke easily and just wouldn't cut anything, but they were two flute.
Just because one lot of cutters you get from China is bad doesn't mean the rest will be...
I've got 3mm,4mm,6mm and 8mm single flute cutters from the seller Jazz linked to and they've been great.
For instance:
http://youtu.be/bWmsunez7sw
...and that's nowhere near the limit of the cutter.
Thanks JAZZ and Jonathan. Seller saved :) Cutters ordered :loyal:
