Re: 3 axis cnc/router bed
If you need to mill alu then a vacuum bed is not much use since it's not going to hold aluminium. A combination of both would be good...
I could make you a bed with an array of tapped holes, or T-slots, from aluminium on my router. How thick would you want it? 20-25mm?
25mm sounds good Jonathan. I guess I need to take the existing bed off, to measure where the mounting holes would be and the sizes etc...?
I have alot of extra unused height above the Z axis rails, so I could move the spindle and Z axis up at least 50mm. I am just a little worried that when I undo the bolts and move it all up, I might not get it all "exact" to less than a mm for trueness and squareness . I have no gauges of any sort, and I wouldn't know which one I needed.
Just measured the distances between each side of the Z axis rails etc... There seems to be a couple of mil out on several parallel measurements. So I guess I shouldn't worry about moving it all. I know I can get it better than this.
Jonathan, how long did it take you to drill and tap all your holes on your bed? or is it an on going process?
AdCNC
Yes it is - I'm just tapping the holes as and when I need them.
dudz
If you can provide a drawing showing the existing hole positions and the array of holes that would be ideal. I've just noticed though, from the thread where we were discussing buying the machine, that the machine already has a tapped aluminium bed so I'm not sure why you need another one?
The existing bed has hundreds of vacuum holes, but only 4 tapped holes. The question is.....do I ruin a half decent vacuum bed by drilling and tapping it all out or make a new one ?. The vacuum bed is only 12mm thick, plus the plastic underneath which is 13mm thick.
Fair enough...
The easy option is to just get the 25mm aluminium plate, mill it to size and drill the array of holes in it. Alternatively use the same thickness, but mill slots into it then add strips on top (something like 1.1/4"x3/8") so that you end up with T-slots which makes clamping much easier. In addition this means you can skim the bed flat a few times, or accidently make marks in it without worrying too much since the strips can simply be replaced which wont cost much.
What sort of clamps are there for that sort of set up ? or do you make your own ?. I suppose 10mm T slots ?
I try to buy everything on ebay for ease. What grade of Alu should I get for the bed ?
dudz
http://www.ebay.co.uk/sch/i.html?_fr...milling+clamps
But you can use just about anything really...
dudz
There are quite a few examples of homemade ones on forums. 10mm should be fine.
dudz
6082 is generally the best value. Aluminium is really expensive on eBay. www.aluminiumwarehouse.com will be much cheaper, or I use Metal Stockists: ASC Metals Lincoln Ltd. - Metal stockholders for East Midlands/North of England as they're even cheaper...
Seeing all my rails are 25mm round (unsupported) do I really need to replace them with supported rails ? I see that most machines of this size only have 16 or 20mm supported rails.
dudz
Yes, if you are not satisfied with the current rigidity of the machine. Even 12mm supported is likely to be stronger than 25mm unsupported over a reasonable distance, but that doesn't meant you should use 12mm:
http://www.mycncuk.com/forums/faqs-p...ted-rails.html
dudz
For much of history most people believed the earth was flat, but that didn't make it flat!
Ok... I have the 25mm Aluminium for the bed. I unbolted the original vacuum bed, and noticed straight away that it is bent down on each end where there are no bearing blocks supporting it. 4mm to nothing, from each end to the center !
I took out the 25mm unsupported rails and rolled them on a sheet of glass to check for bend. Seems all ok. The vacuum bed is pretty flimsy. 2 out of the 4 bearing blocks seem to have had their day ( roll a bit rough ). So I suppose I might aswell replace the 25mm rails for supported ones with new open bearings ; SBR20X900 Precision Supported Rail kit 900mm long CNC | eBay
The rail length I need for the X axis is 850mm. Is 20mm rails (as in the link) going to suffice ?
Also the ballscrew seems fine. But as I am replacing the rails, will the height from the 45mm profile (frame) to the bottom of the new Bed be the same for the new rails and the original ball screw bearing ? The new rails are certainly within 2mm (see pdf on ebay link )
If you're planning on getting the rails from that seller then you can get 25mm for the same price here, or maybe less here if you send the seller a message. I'd go for 25mm since they have one more row of balls than the 20mm rails, so are correspondingly stronger. Having said that either will be a huge improvement on what you have now.
Wow, China again. After shipping plus import tax, do you think the prices would still be better ?
dudz
To England I'm certain they would be, so unless where you live the taxes are even more extortionate, it should be cheaper.
dudz
just for the record i've had to pay £21.50 to fedex a week after i got my deliveries from china, i'm not sure if it's that much due to the fact it come in 2 parcels
hmmmm..... I just payed 37 euros taxes for an item from the US which cost 85 dollars.
I have 45mmx45mm profiles with 10mm T slots. Please could someone point me towards an ebay link that sells the correct T Nuts and bolts for these rails for 45mm profiles. I think the rail bolts need to be M6.
FOUND THEM....thanks
OK. These rails purchased...2 linear bearing slide unit SBR25-850mm rails+4 blocks | eBay
I hope the quality is as good as the ones sold in the UK.
Ok.... I received my Aluminium via UPS. 470mm X 300mm X25mm
I clamped it down to the original bent Vacuum bed (which temporarily straightened it)... planned the new supported rail bearing block mounting holes in CamBam and successfully drilled and counter-bored the holes. First thing I have ever done with this machine since changing the Z axis plate and adding the 2.2kw Chinese spindle. What an improvement so far !
Still a way to go to make it more sturdy, but I am already planning the next improvements to come.
Now... in respect of holes for clamps on the cutting bed.....For now I am going to drill and tap some holes for clamps. (maybe cutting slots later if needed). What size metric holes should I use for the clamps ? M4/M6 ?? and what depth ?
