Anyone had problems setting up one of these 2.2kw chinese spindles??
Thought I had followed the instructions & done it correctly but although you can hear the frequency ramping up the spindle doesn't turn at all. Forward direction lamp is on & if I press jog it runs down, light change from forward to reverse & it ramps up again but still no movement on the spindle.
Spoke with Jazz on the phone & he suggested it sounded like I had set the inverter up incorrectly so went over everything again & can't see where I'm going wrong.
Rather than keep troubling Jazz thought I would ask if anyone else could help or had had a similar problem.
