Re: Identifying Steel types.
It may be 416 stainless, or 303 stainless.
416 is a cheap martensitic variety with lower resistance to corrosion than the 300 series. It machines beautifully. Many linear motion components are made of it (ballscrews and LM guides).
303 is similar, but has lower machinability and does not respond to heat treatment.
You may find 416 in printers. The ground and polished rods that form the base of their LM are typically made from it.
I wish you well in the search for the steels identity.
Having analysed steels in my previous jobs, I can tell you that the analysis does not tell the whole story.
Most steel types have a wide variation of alloying contents and can all be in grade. This is due to the steel being within its physical specifications and the chemical content can vary widely.
From your description it sounds like you got some high quality free machining steel, which I think contains Lead.
Peter
Hi Peter,
Thank you for the response. Can you recommend which steel to ask for and a supplier. I am happy to buy some and see how it compares.
Neil.
Hi Peter,
Neil.
This is probably a silly suggestion, but is the end of the bar painted blue?
From memory (I shall check tonight), one end was painted orange.
Here is a colour chart http://www.alro.com/datapdf/metals/colorcodechart.pdf.
Although it may mean nothing as suppliers usually had their own version.
As to the steel type you need I have no real idea as I only used to analyse them to see if they were in spec, more often than not they had selected the wrong one! Happened more than once!
Peter
ptjw7uk
Peter
If your old company can't select the right one, its not looking good for me :dispirited:
Thanks, Neil.
Some scrap metal merchants have hand held Analyzers to sort their metals, if you can find a friendly one he could probably help
Have a read on this hand held XRF analyser Carbon Steel Analysis, Low Alloy Steel Analysis at Its Best with Handheld XRF | Bruker Corporation
Note how careful they are to skirt the real problem in really sorting the grades of steel, they even mention full size laboratories.
Believe me analysing steel is a big problem using any method and I've tried them all.
Peter
