symmetrical hart shape in vectric v carve pro
hi i wounder if someone can help me please.i am trying to cut a perfect hart shape out. every time i try and cut one out come out not very good at all,i am using v carve pro to trace bitmap the out line but it never traces perfect am i doing something wrong ? many thanks for your help
Re: symmetrical hart shape in vectric v carve pro
hi thanks for having a look for me i have to try in my program as when i try ed to open your saved file it can up that yours it a later version than mine :-( i will try the setting thank you
2 Attachment(s)
I've saved 2 files to dxf, heart1 is a single vector, heart2 is the bitmap tracing of your image.
cross fingers :)
I do a lot of bitmap tracing and the only way I can get a nice clean result is to either use the trace command and then node edit the resulting vectors or manually draw over a background image, drawing and tracing with vectors is nothing like drawing with a pencil, takes loads of practice.
