Re: Traffolyte where to buy?
Thanks for that longy I had seen him and have ordered some but those are all he has available
I dont mind buying full sheets but I dont seem to be able to find a supplier who may have smaller sheets in a variety of colours
Ian
Your welcome, try these sheets up to 24 x 48 (600x1200) Cheapest Traffolyte Material | UK Engraving Services
They never answer the phone ....
I bought some from Germany, cheap enough, but the shipping is silly for small amounts.
Sorotec - Graviermaterial
Well I bought some from the ebay supplier
I've never seen traffolyte in the flesh so to speak before
the smaller bits he does in 3mm are what I imagined ( material that the large hotel key fobs are made of) hard and rigid
the larger bits are 1.5 mm thick and floppy
if i scratch the 3mm thickness with a stanley at 90 degrees the blade scratches... on the 1.5mm it glides..material is soft and plasticky
The seller says they both traffolite but the thinner is easier to bend
any ideas?
If you PM me your details I will post a 100 x 100 piece of the 1.4mm (Silver on Black) I have left over. You can then see if this is what you need.
Rob
Many thanks Rob
I think I know what I want
its just where to get it from
wonder if theres an oppertunity to sell on ebay if i buy much more than i need
Hi Ian,
Are you still looking for a supplier of Traffolyte?
I currently use 3mm Traffolyte for the signage my company produces, but could also get hold of 1.5mm.
We order our material in in large sheets but do have the capability to cut these down to the A4 - A3 sizes that you have mentioned. We also stock various colours.
If this could be of any interest to you drop me a PM back or call me on my works number 0121 558 4411 and can discuss a little more in detail what you require.
hi All
I have the following stock of Traffolyte that i am looking to sellAttachment 27320
The following Traffolyte sheets available ...need to store room
ITEM
DESCRIPTION / COLOUR
SIZE
UNIT QTY Item Wt.
Kgs
Make
3 Colour Traffolyte Flexible Laminate Sheeting
Suitable for Environment Temp of -50deg C to +82deg C
We also have the following colours and sizes available
156 BLACK/WHITE/BLACK 3mm thick 600 X 1200 MM Sheets 90 224.14 Suregrave
157 BLUE/WHITE/BLUE 3mm thick 600 X 1200 MM Sheets FEW 224.14 Suregrave
158a RED/WHITE/RED 1.5mm thick 600 X 1200 MM Sheets 141 251.72 Suregrave
161 RED/BLACK 3mm thick 600 X 1200 MM Sheets 141 224.14 Rowmark
You do realise that this thread is 6 years old?
Thanks Chad,
Only realized that after posting
Chaz,
Are you perhaps looking for any Traffolyte, or do you know of anyone looking for same?
