Re: Not sure what to do...
Take a look through these build logs and see if you can borrow ideas to make your own machine; http://www.mycncuk.com/forums/253-DI...ter-Build-Logs
I don't think you will find a kit but the obvious choice is something like this from ebay; http://www.ebay.co.uk/itm/CNC-3040-R...item3cc034136d
Some people buy these as a first machine to get themselves up to speed on using a cnc machine, then they know what is required if they decide to build one.
It's going to be difficult if you don't have the gear and facilities to build, plus the cost will quickly rise if you have to pay to get stuff made.
Anything for sale here ? http://www.mycncuk.com/forums/188-Items-For-Sale
Your budget is not enough to be useful.! . . . I've seen this time and time again and the outcome is nearly always the same.? Weak Under performing machine that is unreliable that ends up with 1 of 3 outcomes.
#1 It's scraped and started again so the your budget is the price of learning(hardway)
#2 It's modded and upgeaded etc ending up with a machine that is still a compromise and cost twice the price of doing correct first time.
#3 It's frustrated the hell out of you to the point of giving up completley putting off CNC forever.
My advise is wait save up £1000-1200 minimum and do it correctly first time. In the mean time while saving plan and check out every thread then start your own thread asking about anything that your unsure about or can't find in other threads.
If you do this you'll get a nice reliable usable working machine much quicker than rushing in and frustrating the hell out of you.
Good luck.
Your picture seems to show you trying to create a floppy rectangular base from aluminium section and then bolting two supported rails on the top.
I had a quick look on ebay and found a piece of aluminium 600x400x12 for £86 and I wasn't really trying.
Thanks I appreciate the Comments!
I reckon for my first machine I might take EddyCurrents advice and go for the 3040 off ebay, though the 0.05mm repeatability is 25% of my target 0.2mm accuracy which is a bit worrying, but I hope it will be good to get my started?
Many thanks again
Dom
DMW
. . .though the 0.05mm repeatability is 25% of my target 0.2mm accuracy which is a bit worrying, but I hope it will be good to get my started?
No, it's 4 times more accurate than your target
DMW
Many thanks again
Dom
EddyCurrent
But don't believe everything you read on eBay either..... suggest you trawl threads here for 3040 owners and ask what they actually get...
surely it means that it will cut at 0.2mm+/-0.05mm
Which means two cuts that are supposed to be 0.2mm apart could be worst case 0.1mm as each cut can be 0.05mm in the wrong direction?
Maybe, or perhaps I've supped too much Grassmoor Dark Ale ? brain not fully functional
With regard to Irving's post have a read here; http://www.mycncuk.com/threads/6981-...3042#post53042
Low budget machines could lead only to frustration, i believe.
The Alu profiles are expensive for a build.
For me the cheapest CNC should have the following things as a must and then around them build the rest:
-water cooled spindle and VFD.
-reliable breakout board
-reliable motor drivers
-supported rails
Save some more money and buy a mini mill, at least you will definitely return your money producing some quality things.
All these 3040 and so are toys.
Sad but true.
silyavski, you may be correct in calling them toys, but the OP only want's to drill PCB's and some wood so I think they will do that. What he will learn from that experience will be invaluable in deciding the next step.
