For smaller lathes, you can't really go wrong with CC_T insert holders, as the insert choice and cutting angles are a good compromise.
A SCLCR holder is what you'll most likely be looking for, as it's the most versatile in terms of turning/facing.
Have a look at
http://www.shop-apt.co.uk/lathe-turning-tools-apt.html as it shows the directions that the tools/inserts are designed to be used. You can use them in other directions, but it's not recommended.
(and if you're looking for insert parting tools, look at the grooving section, as APT's grooving/multi direction WDN insert tools are pretty good)
