Tiny round over for edging
Hi guys 0/
I'm doing some small boxes 110 mm x 66 mm buy 30 mm deep, out of hard wood. I want to give it a nice round over as the boxes will be hand held. But I'm not sure what to use. I have a full router table and looked at the trend bits, the smallest I could find was :
Dimensions:
D=19 mm
C=3/8 inch
C=9.5 mm
B=9.5 mm
B2=12.7 mm
R=1/8 inch
R=3.2 mm
Shank Diameter=8 mm
I think 3.2 Radius might be to large, I'm really only trying to take of the sharp edges but I want it neat and sanding is a bit hit and miss.
Any suggestions on a bit that could work, I don't need it to be self guiding I can set the fence up to guide along.
Five
Re: Tiny round over for edging
Hi Fivetide
Long time no hear.
I got some small bearing guided roundover bits for doing the same job on Spilka spec windows i made for the house. Think i got them from Wealden tools.
Regards
Mike
If you can't find a smaller roundover maybe you could use a 45 degree cutter and adjust the fence so it was just skimming the arris.
2.4mm radius
http://www.trenddirectuk.com/mb-06x1-4tc.html
Or you could make your own 'scratch stock' from an old hacksaw blade
Just use a portion of the edge of Ogee or Ovolo cutter like Roman ogee or bead ovolo or maybe some other formed tool. It won't give full round over but just breaks the sharp edge.
mekanik
Hi Fivetide
Long time no hear.
Regards
Mike
Thanks guys .. as usual excellent advice :)
Yeah Mike been a while .. had to actually go back to work lol .. bummer ! But I've started puting together a new workshop at my dads house.. bought a small metal lathe as a Christmas present still have the Black Cat CNC.. messing as I always do with ideas :)
Eddy , thats the baby ! I'll try and find one on ebay.. :)
You can get bearing guided 1/16" roundover bits.
Most major manufacturers make them.
http://www.boschtools.com/Products/A...d=85289M#specs
Ger21
wow even better , thanks Ger21
http://www.ebay.co.uk/itm/1-4-Shank-...65517985&rt=nc
GBP 2.93 all the way from sunny China, 1/8" rad just adjust hight and fence so it breaks the corner to your satisfaction.
Mike
OK, I am confused here, not difficult I know but.........
What is the function of the bearing when used on a CNC machine?, surely it is not needed??, not like on a hand held router, or am I missing something here like I usually do??:biggrin:
Because the OP said this, "I have a full router table . . . ", so he's not going to use the cnc machine by the sound of it.
OK, so if I wanted to do the same on a CNC, what would I use?
A similar bit without a bearing.
EddyCurrent
Correct ! I edging the box afterwards.. far quicker imoa.. ;)
ptjw7uk
Thats a great post mate thanks.. i'm going to order one to try it out :)
racerbear02
The same cutter but you can take the bearing off via the allen head cap screw (black thing in the pic).
.Me
