I'm looking for a supplier of Flexible brush strip any one know any suppliers.?
What spec of brush?
There's some useful stuff used in the manufacture of UPVC windows with sliding elements.
Some cut-to-length door strip has a flexible strip in an extruded aluminium section.
Knowing what it's for could help avoid suggestions that don't help?
Regards,
Nick
Top secret.!!. . . .Could tell you but then I'd have to Eliminate you.!!!:cower:
Nah only kidding it's for just for dust shoes and ball screw protection. The window stuff isn't long enough and I need flexible strip type, not the type that has aluminium extrusion or metal bar to hold bristles together.
You want filament length of 75mm+ or strip length of 75mm+ ??
You can pull the easily formed carrier out of the extruded aluminium carrier of this stuff -
http://www.ebay.co.uk/itm/Garage-Doo...item417d7c6b31
3m length with filament lengths up to 300mm
Hi Dean, can't find a uk supplier (yet) but fairly sure this will do the job:
http://www.tanisbrush.com/industrial...ngle-row-brush
Part # fpvc143036 has 3" bristles & 36" long, comes in 72" long too
Might be worth an email to see if they have a UK/eu outlet
What about this one?
http://www.formseal.co.uk/brush-strips.html
I think this lot have someone in the uk as well.
https://www.mink-buersten.com/en/pro...p-brushes.html
Thanks Lads some good Links but ideally I'd like Uk supplier. I'll enquire all the same it's worth asking.
(Web Goblin: I've tried formseal they only have the wire bound type.)
the only place I could find any flexible brush from at a reasonable price is here. Although i've not bought any yet. I haven't found any suppliers in the UK that weren't wanting to sell large amounts at high prices.
What about this thin transparent flexible skirt?
http://www.ebay.co.uk/itm/Clear-Flex...3D231325431235
I realise this is an old thread, but if anyone's interested there's quite a few still available on aliexpress
https://www.aliexpress.com/af/Brush-...nc&blanktest=0
Hi
I have an excellent range of flexible brush strip , from 45mm to 125mm. It fits into an aluminium carrier.
Brush filament's are made from polypropylene so good resistance to oil.
Regards ,
Kevin.
