Need advice on new machine, i am total beginner with cnc.
Need for make pcb circuit with drilling holes. And easy software to work with.
Price is 400-800 USD
Thanks:angel:
Thanks:angel:
Making PCBs this way is very slow, you know?
IME it is better to use a professional fabricator - http://www.kikipcb.com/
Unless you are making rather crude and large PCBs it's a tough job for a mill to do a good job. My PCBs have tracks only 0.2mm wide and similar spacing, that is a difficult ask for an affordable mill.
I use a combination of Eagle to do the design work and the pcb-gcode ulp to generate the necessary gcode files. For the small one off type of thing that I do as a hobbyist, this works fine.
The ulp can be found either on the Eagle site or there is a yahoo group dedicated to it.
I need for small job. Maybe 4-5 pcs pcb year
Example for my job.
http://i01.i.aliimg.com/wsphoto/v0/1...font-b-ECU.jpg
It looks like those boards might easily be handled by Eagle Lite (no cost for a hobbist) and the ulp is also no cost.
Might be a winner setup for you.
So it is free card for eagle lite?, Would be fun to try cnc , but no one has tips on a cnc router with good price and easy to use!
I built my router (about 330mm x 330 mm x ~50mm) and control it with an old DOS program called Turbocnc.
The router was built with and aluminum channel and flat stock. I found some linear rails to use for the X, Y, and Z. Managed to get a spindle (only 70 watts but works for PCB work). used acme lead screws with derlin nuts for zero backlash.
Works for me.
How many PCB can you buy for the cost of a router?
I do it because I CAN and want to do it. Its not a money thing. I do it to prove to myself that I can. A hobby is not all about saving money, sometimes it is proving that you can do it yourself. If it was all about saving money, I would not have any hobbies and simply buy whatever it is. Also, my hobby projects are typically one off types. I have no plans to manufacture a product. So I can go from a board design to finished board ready to populate in less than an hour usually. How quick can you get a turn around on the board (one off) that you want to buy???
Its different strokes for different folks.
Thanks :cool:
Thanks Jazz
At my age, it is projects like this that make me want to get up in the morning and do something instead of sitting around the house all day. I like staying home and putzing around in the shop or dreaming up new projects.
I built my first cnc for the very same reason as alfons37. Took me a while to even get as far as trying to route a pcb. You gotta learn how to cnc before you start on a pcb. Then theres the added complication of levelling, alignment pins for double sided etc pretty soon it all gets pretty darn hard. Prepare to destroy a load of copper boards. You gotta keep in mind when designing the boards that you can expect to route 0.1mm gaps easily so you need to keep your pcb design modest.
To get to the op's question, the machine you need will need to be super precise but not necessarily super strong, if knocking a few microns of copper off the top of a board is all the stress it will get. The chinese machines may well do the job, but you cannot be sure of what you are going to get with one of these. However given your budget, your choice is a cheap chinese machine or none at all.
Saying thanks wasn't enough for me. It's been a while I haven't read one like that. To me, even if the things I make myself never pay back for what I spent for the machine, it's all about the fun to design it, make it, and see it coming to life. That, is priceless. Sorry if I'm off topic, but I couldn't hold myself from sharing :)
My question was actually to the OP who doesn't already have a CNC machine and doesn't have the skills yet. If his goal as set out in the first post is to produce a few PCBs, it will be less expensive and return better quality to use the manufacturer I linked to. £30 will land you a handful of PCBs delivered to your door.
On the other hand, if you are doing this as a hobby then a CNC machine will give you a lot of joy and be highly useful! Alfons37 what is your ultimate goal?
alfons, I just thought I'd return here and add a few pointers that I've picked up while taking my first steps into milling PCBs. Hopefully these will save you a few ruined copper boards!
First level is everything, if your board is not EXACTLY perpendicular you cannot take the really shallow cuts that you would like. Either you will cut too deep in some parts or cut air in others. Set up a touch probe and use something like autoleveller software to level your gcode with your workpiece. It really did the business for me.
I found that MFD makes a particularly good spoilboard for pcbs. Use double sided tape to hold down the copper board. Using clamps just bends the board! A few strips of tape is strong enough to hold it secure and is easy to get off afterwards.
Use alignment pins for double sided boards. You just cannot line uop accurately enough just flipping the board by eye, even using marks on the spoilboard.
Keep in mind that as holes are not plated through you could (likely) have great difficulty in soldering some components, use smd where possible. If you are used to working with commercial grade boards with resist and solder mask etc, its easy to forget this and then realise you cannot actually complete your shiny new cnc made board (happened to me).
Lastly keep your designs modest and your tracks as fat as possible. Even using 0.1mm V bit, its very difficult to actually cut 0.1mm in copper, expect maybe 0.3mm. I'm sure with more experience it will be possible to get thinner cuts. And keep in mind that the extra cut width will come off your track, so it will be narrower than planned.
Hope some of this is helpful to you when you do get to finally mill some copper.
PS Flatcam is great for turning gerber files into gcode and its free!
The reason I used to us a CNC machine to make pcbs was for ultra fast prototyping. I can finish a circuit in eagle & have my board within the hour (vs weeks if using the cheapest chinese fab houses) ...as soon as you have the board, you can start debugging & revision II comes along .....the revision II board can be with me within the hour...rinse repeat.
In short if you are designing circuits, a CNC machine can't be beat for rapid prototyping. Of course once you have your final design...off to the fab house it goes.
FWIW, my design path...
Design board Eagle, then export tracks as gerber & excellon files, then import the gerber/eccellon to do the associated CAM work in Cambam...before finally using CNC-USB to mill the board (CNC-USB has features which are fantastic for pcb milling)
My top tip...find a local signmaker ....checkout their skip...there'll be loads of waste acrylic in there...it's perfectly flat & perfect for use as spoiler.
Even better than ensuring your board is flat ...use probing (which adjusts the Z plane cut depth in sympathy with the boards irregularities (a built in feature with CNC-USB .... https://www.youtube.com/watch?v=0jGY92S8bxM). This method means you don't even need spoiler...my pcb board was always clamped 8mm above my cncmachine's bed...I used tabs to keep the board in place & then just snipped the tabs out at the end.
For double side boards, I used index pins, but again CNC-USB has a feature called 'transformation' which in theory allows you to flip a board over without index pins, the idea is to use a Z mounted webcam to jog to some known coords & then it'll work out the adjustments to ensure your top surface & lower surface are perfectly aligned (this video sort of explains it - https://www.youtube.com/watch?v=JJnenOsbCzU )
