Thread milling shallow bind hole
Hello all
I am needing a little advise please! I don't know about thread milling. What I am wanting is some blind holes in 316 thread milling to take a m12 thread. Could a 6mm deep hole be thread milled or is that just silly and totally impractical? The thread are just going to be little blanking caps just held on with a bit locktite.
Cheers now
Steve
Re: Thread milling shallow bind hole
Hi Steve
No logical reason why you can't do it, hole will have to be flat bottom then i would undercut to slightly over thread dia with tool just clear of bottom of hole then run your thread.
Regards
Mike
Hi mekanik
I appreciate you taking the time to reply. It is great that can be done, I am a happy! Had it not have been feasible I would have been in for a pig of job.
Many thanks
Regards
Steve
suesi34e
Hello all
Cheers now
Steve
Could you not just epoxy the caps in? or do they need to be removed?
You could also use a roll tap, just interpolate a flat bottom hole first then tap to depth. A roll tap would be cheaper than a thread milling cutter.
jamesgates1000
Woukd nit fancy my chances of forming M12s in 316, the bugger galls to easily
Be sure to get a threadmill that is big enough to cut the pitch you need. Bought a 6mm one the other day, can only do up to 1mm pitch....:cower:
A larger threadmill will do smaller pitches though may not be able to get into small holes
I've been looking into threadmills as it sounds like good sport :stupid:....anyone got a good source for them?
Hi Steve
You would be as well doing some test pieces first, as stated Stainless is a bugger.
What's the application ?
Regards
Mike
Got mine at drill services.
I have used thread Mills from wnt or cutwel, both supply quality tools. Roll tapping stainless isn't a problem if you use a good quality roll tap and plenty of rocol.
Hi Clive
Tar very much for the thought. Your question is a good one. I was looking to remove them but that may only be if something fails and the job needs breaking down. I will not dismiss opening the hole up slight larger and getting out the epoxy. Thanks for your help and waves of thought!
Steve
jamesgates1000
Hello tar very much for the thought I will give what you say some consideration.
Cheers Steve
Hello Komatias,
Thank you for your reply. I realize I am not on the direct road for success, with the following
small diameter, shallow blind hole, in 316 no less, limited knowledge and wanting to thread mill it. All that said I may have a go at it.
Steve
njhussey
Hi Neil,
I am not sure so don't quote me on it but I think I got my ones from J&L. I notice you mention thread mills and good sport I notice you don't mention 316 in the same sentence!
I was watching one of your videos earlier in the inspiration thread you build looked to work out a treat for you.
Steve
Hi Mike,
Yes thanks for the thought. I will certainly have practise before picking up the finished parts. The parts are for finishing off nicely m12 stud that protrudes a flat surface. Basically, just a blanking cap.
Many thanks
Steve
suesi34e
Hello Komatias,
Steve
Cool! Was just adding an alternative to the mix with the ground taps. I will be doing some thread milling this weekend but on aluminimu pipe with fine threads M18x1 for my brothers project. Will post findings
Best of luck with that mate. Who know if my findings from my efforts are not too shameful I may post them! After this little job I hope to start a small router build!
suesi34e
Hi Neil,
Steve
Cheers Steve, so far its all good... Just need to get a week on it to finish it off and start the mounting frame...
Stainless is a bugger as unless you use some form of lube the threads gall and snag when tightening so I can imagine it's a bugger to tap and threadmill!
suesi34e
Hi Mike,
Many thanks
Steve
Steve i know this is a silly question but is it not possible to measure the stud protrusion , remove the stud and machine the protruding length from the end ?
Mike
njhussey
Yes mate, it is a bugger in my book especially when not best geared up for it!
Congrats on your build happy CNCing
Steve
Hi Mike,
Tar very much for the thought and I don't think it is a silly question! I had tried to see it is was possible. Had I have known to cut the stud down prior to the whole assembly being welded up I could have. As for now I don't think I can get on the stud in anyway to cut it down it protrudes up through a large flat plate that is mirror polished so easy to scratch etc. I think I will just look a slightly larger pocket to hug the threads and stick it on like you said.
Tar very much for the help
Steve
hi Steve
Have you thought about using stainless dome nuts that you would fit on a cylinder head, maybe thin them down a bit.
i own 3x tapmatic tappings head, but since switching to thread mills ive not used the tapping heads once.
thread mills are ace, the best thing ever.
granted i use m2 and m3 threadmills in ally, but i always get good results.
what you could try is altering the dia of the threadmill in the coding setup, so do a few passes getting deeper (or wider, till you reach the tools actual dia) and deeper till you have taken the correct amount of material off. the good thing with thread mills is you dont have to take the full depth of cut in one go.
hope this helps
Hi mekanik
Thank you very much for the thought. I tried a dome nut but I just didn't suit the look of the parts so I moved away from it. I think after a good bit of figuring out I am getting there with the caps.
Many thanks
Steve
mekanik
hi Steve
Hi andy_con
I like the idea of the thread mills and thank you very much for you advice. I just hope I don't go wrong a break a tool I don't have too many of them!
Many thanks
Steve
andy_con
hope this helps
Like I say do it in a couple of passes.
Make the treadmills dia bigger and you will only take a small amount of material away. Reduce the dia and you will start to take more material away.
Very simple
suesi34e
Hi andy_con
Many thanks
Steve
Hi Andy,
Thank you for your help. I will see what I can do not sure how simple it will be!
Many thanks
Steve
andy_con
Very simple
Very simple, spec sheet will give you exact dia of threadmill so just make it bigger
Many thanks for the help and advice.
