Hi All,
To re-arrange my cnc workbench to make life easier, I need to extend the 4 pin cables from the stepper motors. Does anyone know where I can purchase such cables?
Gary
Hi All,
Gary
We need to know what type of cable you require, it is quite normal to use 4 core cy cable as: http://www.csecables.com/flexible-co...creened-cable/ 0.75mm or 1mm
Make sure you connect the cables core to core and not get them crossed the cables cores are black but do have numbers on them
Hi Clive,
Yes, that is the cable. The large flying socket fitted on my cables is the XLR 4 pin type that screws into a panel mounted plug on the cnc controller. I cannot find any screw type flying plugs that fit. I may have to replace all the cables :(
Gary
just search fleebay etc for "4 pin aviation plugs"
Its going to take you far longer looking and asking than just fitting new cables.
BTW 4 pin aviation plugs are NOT XLR's
Maplin have the plugs & have sockets in line and chassis mount in stock in my local store,
- Nick
I was going to recommend Audiospares Derby, but just found out they went belly up last year.
Amazon do them https://www.amazon.co.uk/BQLZR-Silve.../dp/B00IJ673ZW
If you can wait for delivery - http://www.aliexpress.com/item-img/10pcs-lot-Silver-Metal-Aviation-Plug-Panel-Power-Chassis-Male-Female-Wire-GX16-4-Pin-16mm/32528830022.html?spm=2114.10010108.1000017.2.5oYF2 8
Hi All,
Thanks for the information, I found the correct plugs and sockets on ebay.
Gary
Hi...i think its not such a big issue. Easily you can find that type of cable anywhere. Try from local store or you can try it online also. If still you will not be able to find it then go for building it by yourself. Just take a ribbon wire with you and some connectors and you can build it.
pcb component assembly
PCBA
is there a maximum length they can be extended?
